Choosing an amp clamp
- tiride62
Thanks for any help.
This is a capture I took off a GM 3.6L, with an AESWave low amp probe .
This was taken with a 2V scale on the compression trace, so no attenuator was required.
- tiride62
Thanks for the speedy reply. Could I ask what a compression trace is?Tyler wrote: Congratulations on getting your scope!
Personally, I'd get a low amp probe first, and worry about the high amp probe later (or never). I've always used a low amp probe for relative compression on gasoline engines, and never had any problems. Diesel is another story, due to higher starter current draw.
Can you link me to the Hantek clamp you were looking at? The other consideration with low amp probes and relative compression testing is the inside diameter of the jaws. You want as wide as possible to fit around thick battery cables, or you won't get an accurate reading. The AESWave clamp measures out at just over 9mm.
- tiride62
www.hantek.com/en/ProductDetail_15_77.html
I'm in Canada so shipping is an issue from AESwave. I had to send my ScannerDanner book to my buddies in USA to make it more reasonable, Hantek I can get off Amazon.ca.
tiride62 wrote: Hantek one is the same, 9mm. That was a concern as well. Here's a link to the Hantek website.
Ahhhh right, what a pain.
- tiride62
- Ro-longo
- North Salt Lake, Utah
- Thank you received: 43
I've used my Snap-On low amp clamp a few times on Diesels with no problems.
The above was taken off a Ford 6.4L with a broken exhaust rocker arm. This is how I test compression on all the Diesels I work on, I don't even own a Diesel compression tester. Just use the relative compression test.
- tiride62
Any suggestions then?Andy.MacFadyen wrote: Avoid Hantek curent clamps if you can the quaily is pretty poor I have both high and low curent versions. The low current has an eye that is too small to fit over most alternator cables and the high curent clamp was delivered with a faulty switch. The tactile feel of the switches is poor and on both tools the the LED to show the unit is switched is so dim it can hardly be seen which can easily result in finding the battery dead next time you go to use it.
Watiride62 wrote: Any suggestions then?
In North America I would probably look at what AESwave have to offer via the link on this site.
Very similar DC Amp clamps are sold under the Sealey brand in Europe I am going to order a Sealey TA311 in the near future to replace my high range Hantek.
I don't actually use the high range clamp much usually I do cranking voltage compression tests rather than current tests and I check alternator current with a Uni-T UT203 clamp multimeter. The low range amp clamp on the other hand is a very much used tool.
- tiride62
I'll take a look. Not the right spot to ask but maybe you can direct me to a video or post that explains the difference between voltage compression test and current compression test?Andy.MacFadyen wrote:
So in voltage compression test a high voltage peak = a low compression cylinder.
- tiride62
That was a simple, easily understandable explanation, you might have a future in teaching, LOL. Thanks again; GaryAndy.MacFadyen wrote: It is really simple put the scope across the battery + & - and crank the engine the peaks and troughs of the voltage trace are a inverted version of current trace.
Ro-longo wrote: I've used my Snap-On low amp clamp a few times on Diesels with no problems.
Interesting. :huh: I've tried it on a Dodge 5.9L and 6.7L, ended up burying the probe, or chopping off the peaks of the waveform. Ended up falling back to a voltage compression waveform, like Andy mentioned.
- Ro-longo
Now that you mention it, I don't think I have used it on a Dodge, I mainly work on Ford "Powerjokes"
Ro-longo wrote: Now that you mention it, I don't think I have used it on a Dodge, I mainly work on Ford "Powerjokes"
:lol: :lol: How have I never heard that before? Love it!
- tiride62
tiride62 wrote: Ended up getting one from AESWave, an ES 695. Works fine with my DVOM but can't get a waveform to save my soul on my scope. It's most likely me but I've tried every possible combination of settings and nothing that looks even remotely like a current ramp. Scope is a Labnations Smartscope, it's not automotive friendly and I'm new to this so not a good combination. If I get a uscope any guidance on what accessory's I would want to be able to read waveforms for injectors and coils?
Hmmmmm, I'm not familiar with that scope, but I don't see why they wouldn't work together.
If you do go for a uScope, you'll likely need one of these adapters . The master kit comes with one, the basic does not.
- tiride62
