Re:HID bulb/module testing
  • Tyler's Avatar Topic Author
5 years 1 month ago #51190 by Tyler
HID bulb/module testing was created by Tyler
I brought this up to the group chat awhile ago, but wanted to revisit it with the community. Around here, when a vehicle comes in with an inop HID headlight, it can become a mess. :silly: Try a known good bulb, then sell a new headlight assembly or HID module when that doesn't fix it. It goes from cheap to $$$$ quickly.
What's the better way? I started playing around with a used Subaru HID headlight assembly for giggles. Headlights themselves are becoming more and more inaccessible, so I figure it'd be awesome if we could use a current probe at a headlight fuse to do our testing. :) I hooked up our test headlight and got a current waveform during normal, working operation:
And here's a zoomed in view of the bulb 'lighting off' for lack of a better term. I don't know HID bulb operation like I should. :blush:
So we know how much current a working bulb should consume. Great. Now I cut the outside of the electrode to simulate an open bulb. I added a voltage trace on channel #2 to show when voltage was applied.
It would seem to me that the HID ballast/module is trying to light the bulb off, fails, then gives up. :silly: This behavior was repeatable. I don't know about the internal construction, but there would seem to be some kind of logic at work.
Then for giggles, I damaged the module itself, and retook the capture:
Can we infer that, if we see an attempt by the module to ignite the bulb, that the module is good? And that power/ground to the module is good? I'd welcome your thoughts.
5 years 1 month ago #51199 by Ben
Replied by Ben on topic Re:HID bulb/module testing
It does appear that way, but I wonder what real world damaged modules look like if they may act all together? In what way was this module damaged ? Shorted output? Over voltage? Secondary ignition spike? Did you try testing voltage on the output before cooking it?
5 years 1 month ago #51204 by Tyler
Replied by Tyler on topic Re:HID bulb/module testing
Good question! I took this capture off an '05 Acrua TL with inoperative headlights:
Based on previous experience, I took a shot that the bulb was blown and that the rest was OK. Customer took the vehicle. Never got to fix it. :(
In what way was the module damaged? I don't remember. :blush: :lol: I actually took these captures in January, but never posted them immediately. I've slept since then. :silly:
5 years 1 month ago #51220 by juergen.scholl
Replied by juergen.scholl on topic Re:HID bulb/module testing
 A couple of months ago I watched this interesting studies by Hans Jorgensen. I have not tried it myself though..
5 years 1 month ago #51226 by Tyler
Figures that TBT beat me to it. :silly: But I do feel better that I'm on the right track.
I'll have to find anther sacrificial headlight to play with.
5 years 1 month ago #51228 by Matt T
Replied by Matt T on topic Re:HID bulb/module testing
I wouldn't recommend taking voltage measurements on the ballast output. IIRC it takes several thousand volts to start these things.
5 years 1 month ago #51230 by juergen.scholl
I think it was Rick who mentioned that's a great way to kill a scope...
Nevertheless you could just use a capacitive secondary pick up with a 1:5000 (snap on) or 1:10000 (pico, hantek, Autel) attenuation.
4 years 9 months ago #53681 by Tyler
Another example off a 2011 Acadia. The left front is working correctly:
The right front is not:
Zoomed in, it appears the ballast keeps trying to light the bulb and can't do it:
I'll follow up when this gets a new bulb next week.
4 years 9 months ago - 4 years 9 months ago #53716 by Tyler
New bulb went in. This is the right low beam after:
Note that this bulb only comes as a bulb/ignitor assembly.
Last edit: 4 years 9 months ago by Tyler. Reason: derp
4 years 9 months ago - 4 years 9 months ago #53717 by juergen.scholl
New bulb went in.
This takes away the pain to distinguish between faulty igniter and bulb. Glad the manufacturer didn't decide (yet?) to sell a complete replacement car when the headlights go south :whistle:
The fault capture looks like the igniter tried it's thing but the bulb was bad. If so, did the igniter stop its fruitless intents after a while or went it on forever?
Thank you for the update.
Last edit: 4 years 9 months ago by juergen.scholl.
4 years 9 months ago #53719 by Tyler
It wasn't clear in the capture, but yes, the ignitor (or the control module?) eventually quit trying to light the bulb on its own. I can go back and look at the capture, but it wasn't long. Two or three seconds. It would not attempt to light the bulb again until I cycled the headlight switch.
Some kind of logic in the ignitor or control module knew there was something wrong. :)
4 years 5 months ago - 4 years 5 months ago #56530 by Tyler
Following up to this thread as I encounter more broken vehicles. :cheer:
2011 Grand Cherokee 3.6L comes in with a complaint about the headlights. Left no workie, right is fine. B162C backs up what we already know.
Zoomed out shows a strong in-rush spike, followed by...very little. Some noise, really. Customer has already put their own bulb in it. I suspect the ballast is smoked. As in, it's not capable of igniting the bulb.
If this customer goes for the repair, I'll follow up with an after waveform.
Last edit: 4 years 5 months ago by Tyler.
4 years 4 months ago #56797 by Tyler
Soooooo the Jeep from my last post left without a repair. :( Oh well!
I came across another opportunity in the form of a used headlight assembly from a late 2010's Hyundai... something. :silly: Sorry I don't recall the exact YMM. Anyway, I extracted the HID bits from the headlight itself and got them out on the bench:
Pretty simple, really. Switched power and steady ground.
The ballast/module is made by Osram. I'm kinda mad now that I didn't take note of the OE manufacturers on all the other systems I've tested. :angry: The way different OE's react to failures might be worth knowing.
Also worth knowing that the stated output voltage is 42V. I thought these things ran several thousand volts? Or, does the ballast supply 42V to the ignitor, and the ignitor is the high voltage component?
Anyway, onto the testing. This is a known good shot of the bulb in normal operation:
Some good current flow going on, and a couple solid spikes when power is first applied.
Now I remove the bulb from the ignitor:
While this is happening, there's some pretty good arcing going on in the ignitor socket. :silly: More than enough to light your grill. The really fun part is that this three-arc pattern is repeatable. Apply power/ground, three arcs, then nothing, even if you leave the power connected. More evidence that the module knows something is wrong and moves to protect itself.
Then I disconnect the ignitor from the ballast/module:
Again, the three-arc event is repeatable. Just a lot less noise. The module still knows something is wrong.
If anyone can think of a good way to mutilate this rig to tell us something we don't already know, I'm listening. :cheer:
Time to create page: 0.455 seconds
