Multimeters and amp clamps
  • Chevyman
  • Chevyman's Avatar Topic Author
4 years 11 months ago #52667 by Chevyman
Multimeters and amp clamps was created by Chevyman
I was wondering what everyone would suggest for a entry level multimeter and amp clamp. Working on a limited budget right now but I want to get the best meter I can at the moment.
4 years 11 months ago #52668 by Tyler
Replied by Tyler on topic Multimeters and amp clamps
For a multimeter, I'm still a fan of the Owon B35T+. I've had one for several years now, and it's always performed better than its price tag would suggest.
www.amazon.com/OWON-Multimeter-Measureme...rding/dp/B01C3IQDE8/
The Bluetooth function comes in handy more times than you'd think. ;) As for an amp probe, you really can't go wrong with AESWave:
www.aeswave.com/Current-Probe-Low-range-...ana-Plugs-p9501.html
There are cheaper low amp probes out there, but I don't have any experience with them. I'm not sure I'd want to spend much less on an amp probe, anyway. :silly:
4 years 11 months ago - 4 years 11 months ago #52677 by Noah
Replied by Noah on topic Multimeters and amp clamps
I will say that I like the owon meter, but after lending it out and having it come back with a blown fuse, mine no longer measures amps.
I also am in the market for a new meter. I will probably buy another owon and just not loan it out
Last edit: 4 years 11 months ago by Noah.
4 years 11 months ago #52685 by wowcoop
Replied by wowcoop on topic Multimeters and amp clamps
pretty cool you can get a graphing meter for $61.00!!
4 years 11 months ago #52688 by juergen.scholl
Replied by juergen.scholl on topic Multimeters and amp clamps
Noah,
on the high amp range I´ve seen the soldering melting where the shunt resistor is attached to the circuit bord, although usually on cheaper meters. Nevertheless it may be worthy to have a close look. Do you have continuity between the terminals with the fuse in place?
4 years 11 months ago #52699 by Noah
It's not a graphing meter like the Snap On Vantage you might have seen in some Scanner Danner videos. You can plot the measurements to a graph via an app on your phone, but it's not nearly fast enough to pick up sensor signals or anything like that.
Juergen, thank you for the advice! No matter what I measure, the reading maxes out at 30ma. I have taken it apart and all the solder joints look nice and shiny. I did try to re heat the solder holding the shunt to the board but it made no difference...
