Pcm control current
  • autojoe
4 years 10 months ago #53331 by autojoe
Pcm control current was created by autojoe
Can someone tell me what is MA draw on a control circuit? I know scanner Danner mentions it in several videos. Like on a relay or a driver for a coil? My regular test light puts out about 130 Ma. I was watching this YouTube video on it being a danger to use led one. I know not true I have used regular one for years. Thank you
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 10 months ago #53336 by VegasJAK
Replied by VegasJAK on topic Pcm control current
Without seeing your control circuit diagram to address MA, mA is milliamps. That is 1/1000 of an amp. Your test light puts out 130mA. You used Ma which would be incorrect to address milliamps.
Paul stresses to know the mA for your test light. Notice he uses the incandescent test light almost exclusively but in some rare cases he uses an LED.
Paul is by far the expert in this. I trust and listen to him.
Hope this answers your question. :)
  • autojoe
4 years 10 months ago #53339 by autojoe
Replied by autojoe on topic Pcm control current
I understand that. I have used test lights that draw 170 Ma. No problem at all. I know relay control circuits draw about 1 Amp. One of these days going to test the current draw. I have watched every one of his videos when first started on YouTube then on the premium channel
4 years 10 months ago #53363 by Tyler
Replied by Tyler on topic Pcm control current
The current draw on a control circuit will vary largely on the circuit. You can sometimes use service info on the circuit/component in question to get the specified resistance and let Ohm's Law give you an *estimate* of what the current draw will be.
That video is a little... confusing. :unsure: I get the message perfectly. But, if I probed the wrong wire with my incandescent test light during an inspection without understanding the circuit in question, then whatever gets cooked isn't on my test light - it's on ME. Same thing with like-colored wires. You can't go eenie-meenie-minie-mo, pick one, hope for the best then blame equipment when you let the magic smoke out.
'Computer safe' should be rephrased to 'human safe'. :silly:
  • autojoe
4 years 10 months ago #53369 by autojoe
Thanks for the reply. I understand control circuits just seen many people misunderstand and advise against them. I know test light is a buffer in case you do something wrong. I have a ammeter that will measure down to 1 Ma. Maybe one day I will do some measurements for my own behalf.
4 years 10 months ago #53391 by Tyler
Let us know what you find. B)
Since watching SD material, I've made it habit to measure every test light or load bulb I use regularly. I then Sharpie the draw amount on the light/bulb for reference later. Makes choosing the right bulb for the circuit being tested much easier.
The following user(s) said Thank You: Noah, ProperDiagnosis
Time to create page: 0.359 seconds
