Fuel economy in cold climates ...
- dannydebont
4 years 8 months ago #54190
by dannydebont
Fuel economy in cold climates ... was created by dannydebont
Good morning gents/ladies,
In colder climates air is more dense, therefore more air enters into the combustion chamber by volume, hence more fuel is needed to maintain the stoichiometric ratio and prevent burned valves. Is it safe to say then that in colder climates a vehicle's fuel economy is worse than in warmer climates? If this is true then the fuel economy will degrade even further with any sort of forced induction?
Thank you
Danny
Thank you
Danny
4 years 8 months ago #54194
Replied by Andy.MacFadyen on topic Fuel economy in cold climates ...
Lower temperature and atmospheric pressure definitely increase power because the engine has a higher mass air to burn.
But on spark ignition engine the volume (and therefore mass) of air entering the cylinders is controlled by the throttle butterfly It is like turbo charging the fuel consumption will only increase if you use the extra power.
4 years 8 months ago #54195
The following user(s) said Thank You: dannydebont
