2007 modis EEMS300
  • boatmoter
  • boatmoter's Avatar Topic Author
4 years 8 months ago #54492 by boatmoter
2007 modis EEMS300 was created by boatmoter
Hi all,retired tech,used to use a modis ms300 yrs ago,just purchased a used one that has the 14.4 build which can scan up to 2013 domestic vehicles.would like to get a update to be able to scan up to 2016 vehicles,I only maintain my own vehicles now, can this modis be updated? it does have the mini usb port in the handle,if so,how do I update it?
4 years 8 months ago #54494 by Noah
Replied by Noah on topic 2007 modis EEMS300
It cannot. Only a Snap On rep can perform updates and that tool is no longer supported.
The following user(s) said Thank You: boatmoter
4 years 8 months ago #54524 by Hardtopdr2
Replied by Hardtopdr2 on topic 2007 modis EEMS300
A subscription would update it to the latest software version available my local rep say he can do it.
  • boatmoter
4 years 8 months ago #54715 by boatmoter
Replied by boatmoter on topic 2007 modis EEMS300
another question bout the EEms300, has the 14.4 build.. will this program a key or FOB on 2002 to 2013 vehicles??
4 years 8 months ago #54725 by juergen.scholl
Replied by juergen.scholl on topic 2007 modis EEMS300
This depends.....mainly on make, model etc.
To program a key often you need other critical information like a pin/immobilizer code. The tool will NOT pull this information. You will find that most time you'll need dedicated tools for key programming. Though on some GM product of the mentioned era the MODIS will allow to enter the 3x 10 minutes relearn procedure, for example.
FOB learning is similar, it will be much more miss than hit, especially on non domestic vehicles.
  • boatmoter
4 years 8 months ago #54726 by boatmoter
my vehicles are, 2002 pt cruiser, 2006 sebring , 2011 malibu,I only work on my own vehicles now Im retired
4 years 8 months ago #54727 by juergen.scholl
The mentioned Chrysler products require a secret key code to program keys. The Malibu probably features what's called a PK 3 system. Check wether these digits are engraved in the blade of an original key...
Sum up: the MODIS will not really help you with key programming on your vehicles.
