Backprobing and T-Pins
- MrMike
- Thank you received: 4
4 years 7 months ago - 4 years 7 months ago #55154
by MrMike
"The object of war is not to die for your country but to make the other bastard die for his"
Backprobing and T-Pins was created by MrMike
Hello-
Ive seen quite a few various videos of people backprobing harnesses and looks fairly simple but I wanted to make sure I do this correctly even as a Retired/DIYer. I know you not supposed to just ram jam the probe in and looks like the proper way is to not drive the pin directly into the wire, but towards the top edge and connect to the actual connector inside the harness?
The other question I had is what size T-Pins should I get or can I just make some homemade ones out of paper clips?
Thanks-
Thanks-
Last edit: 4 years 7 months ago by MrMike.
4 years 7 months ago #55157
Replied by Andy.MacFadyen on topic Backprobing and T-Pins
You have to be extra careful not to cause a short using T-Pins especially when back probing more than one connection on a multi-connector block. You will see them in older videos most techs don't use them since proper acupuncture probes became available.
4 years 7 months ago #55159
I wouldn't recommend using paper clips. However, I would be lying if I said that I have never used paperclips (with a the end filed to a point). You can get a box of "T" pins in the sewing section of Wal-mart, or a similar store. As for the size, the smaller (and less intrusive), the better.
The most important thing to remember, as Andy pointed out, is that there is a danger of shorting "T" pins together, especially when using more than one in the same connector. Even with the preferred acupuncture probes, there is a danger of shorting terminals together, inside of the connector, if you do not insert them straight.
Replied by Chad on topic Backprobing and T-Pins
That is correct. Slide the probe along the outside of the wire, in between the weather seal and the wire. Slide it in, just far enough to make contact with the wire terminal, inside the connector.the proper way is to not drive the pin directly into the wire, but towards the top edge and connect to the actual connector inside the harness?
- MrMike
4 years 7 months ago #55162
by MrMike
Replied by MrMike on topic Backprobing and T-Pins
OK- I got it- Thanks you techs
4 years 7 months ago #55164
Replied by Tyler on topic Backprobing and T-Pins
If you see yourself doing much backprobe testing at all, I'd suggest investing in a set of the uMicroBackProbes:
www.aeswave.com/uMicroBackProbe-Minimum-...onnectors-p9481.html
The cost per probe is significantly more than a box of T-pins. :silly: But they're that nice.
- MrMike
4 years 7 months ago #55173
by MrMike
Tyler- those are some nice probes- I think I might get a set
Time to create page: 0.325 seconds
