Ignition Coils
- MrMike
- Thank you received: 4
4 years 7 months ago #55282
by MrMike
"The object of war is not to die for your country but to make the other bastard die for his"
Ignition Coils was created by MrMike
Hello all-
How do I test my coils the correct way? I've got a 2010 Dodge Ram 1500. I've heard people say with a test light, but I thought it was done with a DMM?
Thanks,
MrMike
Thanks,
MrMike
4 years 7 months ago #55285
Replied by Noah on topic Ignition Coils
There are quite a few methods, some high tech, some not so reliable.
This is my preferred tool for testing ignition coils.
It's simple and it works to stress the coils and expose a weak or borderline coil that may be failing under a load.
Lisle 20700 Coil-on Plug Spark Tester www.amazon.com/dp/B00IXMA1RY/ref=cm_sw_r...Y19WXZ4FTT47PDHWQ372
- MrMike
4 years 7 months ago #55288
by MrMike
Replied by MrMike on topic Ignition Coils
Thanks Noah-
Ill check it out and let you know if I order it
