Diagnostics magazine
  • MrMike
  • MrMike's Avatar Topic Author
4 years 7 months ago #55304 by MrMike
Diagnostics magazine was created by MrMike
Hello-
This might be a dumb question, but is there a diagnostics magazine that anyone is aware of- say for a monthly subscription? Just wondering-
Thanks.
MrMike
"The object of war is not to die for your country but to make the other bastard die for his"
4 years 7 months ago #55319 by Noah
Replied by Noah on topic Diagnostics magazine
I get Motor Age, not strictly diagnostic in scope but there's usually some good articles.
  • MrMike
4 years 7 months ago #55324 by MrMike
Replied by MrMike on topic Diagnostics magazine
OK Noah- Ill check on what they want for a subscription
4 years 7 months ago #55325 by juergen.scholl
Replied by juergen.scholl on topic Diagnostics magazine
You can subscribe to the digital edition without charge. Another , similar option has been Motor Magazine which unfortunately vanished after 2020. Nevertheless the issues are archived and downloadable.
www.motor.com/magazine-issues/
4 years 7 months ago #55328 by Noah
It's free, just the way I like ;)
4 years 7 months ago #55329 by Matt T
Replied by Matt T on topic Diagnostics magazine
Gears is another one. Mostly transmission related but does have some other diagnostic content. Free online but you might need to be an ATRA member to get the treeware??
gearsmagazine.com/current-issue/
  • MrMike
4 years 7 months ago #55330 by MrMike
Yeah- Im good with "free" as well- I was not aware or a free digital subscription. I do have a question that is not related to this so hopefully I wont get busted asking it. Here it goes- In regards to ignition coils-(COP), what is the wire called that fires the spark? Is it called the trigger wire or something else. Also, looking at the Mitchell wiring diagram for my 2010 Dodge Ram 1500, looks like this trigger wire is straight from the PCM? This might seem like a mundane question, but Im just a DIYer living in the back woods of WV and dont do this for a living.
Thanks,
Mr Mike
4 years 7 months ago #55332 by juergen.scholl
On COPs with 3 or 4 wires the actual ignition module/circuitry is integrated into the coil housing. One of these multiple wires will carry the control signal from the ECM to the module telling it when to fire the coil. This may be called trigger, control signal or whatever fancy term you do prefer. Its job is just to tell the COP when and how to fire.
On two wire design - eg. Ford, Jeep - the coil firing is controlled by a power transistor which lives in the ECM. When turned on current flows through the primary coil and when switched of high voltage is induced into the secondary resulting (hopefully) in a spark jumping the electrodes' gap.
  • MrMike
4 years 7 months ago #55346 by MrMike
So, on Ford's and Jeeps the transistor in the PCM basically is the voltage switch? What happens if the transistor where to take a dump? Would the entire PCM need to be replaced?
  • MrMike
4 years 7 months ago #55347 by MrMike
Hey Matt- Ill look into the Gear One mag and see
4 years 7 months ago #55348 by juergen.scholl
Not necessarily.
It will depend on design, parts availability and skills. The Ford escape V6, 3 Liter, around 2008 to 2014 is an example where bad coils were to take out the pcm in the long run. Recommended procedure is changing all coils and the pcm, though you may get away with swapping in a new power transistor.
  • MrMike
4 years 7 months ago #55360 by MrMike
Thats interesting- I guess it depends on the make alot from what your saying. I can just imagine what kind of thought process it is for the engineers, but Ive heard alot of techs complain of engineer designs in all this. Kind of like cars known for electrical gremlins.
