Scan tool BiDirectional control on older vehicles
- rjkpilot
4 years 6 months ago #55952
by rjkpilot
Scan tool BiDirectional control on older vehicles was created by rjkpilot
I don’t need super bidirectional functions on new Jags and Teslas , all I’m looking for is a tool under $800 that has service control functions for things like EVAP valves and sensors, fuel injector control, etc , for mid 2000 us cars ,very hard to find specific information on compatibility , looking at Autel, Launch , etc
Thanks,
R
Thanks,
R
- Bigfoote13
- Thank you received: 2
4 years 5 months ago #56298
by Bigfoote13
Replied by Bigfoote13 on topic Scan tool BiDirectional control on older vehicles
I use the ThinkCar pro. It is a Launch clone of sorts with better graphing. I purchased to for just over $800
=Doug
=Doug
- 70monte
- Thank you received: 29
4 years 5 months ago #56303
by 70monte
Replied by 70monte on topic Scan tool BiDirectional control on older vehicles
I use the Thinktool Pros which you can get occasionally on sale for a little over $800
- rjkpilot
4 years 5 months ago #56355
by rjkpilot
Replied by rjkpilot on topic Scan tool BiDirectional control on older vehicles
Thanks for the suggestions
R
R
- Oltronj
3 years 11 months ago #58963
by Oltronj
Replied by Oltronj on topic Scan tool BiDirectional control on older vehicles
Will the Think tool pros work for things like bleeding the abs and setting the cam crank correlation on the 96 to 2000 vintage gm trucks?
- 70monte
3 years 11 months ago #58965
by 70monte
I know the Thinktool Pros will adjust the cam/crank correlation on those years of GM trucks because I own two 98 Chevy trucks and have used it to check and adjust this setting. I'm not sure about bleeding the ABS system as I have never needed to do that but I'm sure it can do it. This scan tool has 34-35 maintenance functions depending on how old the scanner is.
3 years 11 months ago #58976
I can't speak for the Thinktool Pros. But I know at least some of their software is licensed from Launch. :huh: My Launch Pro Mini has been surprisingly good with older GM vehicles. It's saved by bacon more than once with functional tests it could do that no other aftermarket tool could.
Replied by Tyler on topic Scan tool BiDirectional control on older vehicles
