Dyvo load tester
- bjørn.ali.stokman
- Thank you received: 5
I have seen kbueldiag @instagram use it, and that's where I first saw it.
We've finally got one at my job, and it has made my life so much easier.
Wondering if anyone else had any experience with it?
dyvo.us/
Parts cannon first, then diag.
- juergen.scholl
- Active partschanger
- Thank you received: 462
I don't feel like buying a pretty limited volts only meter at a pretty high cost. On any standard DVOM there are more than at least a dozen different functions, and this one does voltage drop only?? Get a loadpro if you feel like.... You could get a Fluke 87 or 88 for that money and do SO MUCH MORE!
On the website I do not see specs like accuracy, sample rate, load resistor value...
IMO it's almost an insult to any tech's intelligence suggesting they can handle go/no go red and green light indicators but not so much think about what they're actually doing.
- bjørn.ali.stokman
It is designed with ease of use in mind, so that people that don't really appreciate diagnostics can use it.
It however does have a display with voltages on the screen as you can see.
Which is what I use to determine a good or bad wire.
And the specifications are all on their site, you just have to expand the menus.
And because of the Lead's you would be able to see if there is a pwm signal on that wire or just a steady supply.
Which I guess would be difficult on a dvom.
- juergen.scholl
A 100 bucks DVOM will give you pwm, duty cycle, frequency, min/max, bar graph for rapid transistions...
Not sure what you mean by appreciating diagnostics, but it sure helps to know what you're doing and be able to put a voltage reading into context.
- bjørn.ali.stokman
I myself do not like this, but people are different.
I'm not saying this tool should replace anything, but it its 180$ for the basic kit?
The site also offers a calculator for finding ohm values, if you want to use it for that.
- juergen.scholl
- bjørn.ali.stokman
dyvo.us/dyvo-learn-more/
Here is the link, you have to scroll down, and there will be a tab you can open to read more features.
- juergen.scholl
I watched the fuel pump testing video on their site. I think what you said sums it up pretty well:
That's it. Part Power Probe, part Load Pro, part DMM. To savvy diagnosticians, it looks like voltage drop testing with extra steps. :silly: But to the uninitiated/uninterested, there's value in the Dyvo.
In that way, I put it in the same class of tools as the PDT Heartbeat 1001:
www.parasiticdraintest.com/products/?id=
You can do the same thing with an Owon multimeter and about $100 of Wish parts. But the PDT wraps it up in an easy-to-use package and makes the results clear as day.
- Cheryl
- Thank you received: 215
- 70monte
- Thank you received: 29
- bjørn.ali.stokman
