Hantek 20:1 attenuator voltage limits
- ksat22
- Thank you received: 9
4 years 5 months ago #56171
by ksat22
Hantek 20:1 attenuator voltage limits was created by ksat22
The max voltage on the HT201 is 300V. I hear primary ignition voltage can spike as high as 400V. Although the product descript, for what it's worth, says u can use it for scoping the primary, I was wondering if I'd be risking my scope at all using it.
Picco's 20:1 apparently is also rated at for the same voltage and someone who posted a similar question on their site got a reply from the admins that it was okay to use it for that purpose as the high voltage spike is so brief that it won't have time to affect anything.
Am I worrying for nothing?
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 5 months ago #56184
by juergen.scholl
Replied by juergen.scholl on topic Hantek 20:1 attenuator voltage limits
Though the spec is an information to consider I have used both pico and hantek attenuators on higher voltages than the mentioned 300V, specifically primary voltage. Nothing has become damaged.
I believe the 300 V is the designed operating range but there is (hopefully) a significantly higher "burst" level, comparabel to a pressure sensor. I do not believe the short time span being a factor as too much will be too much, in electronics and elsewhere.
- ksat22
4 years 5 months ago #56189
by ksat22
Replied by ksat22 on topic Hantek 20:1 attenuator voltage limits
Thanks, That's good to hear.
