Unknown cable ID
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 4 months ago #56585
by juergen.scholl
Unknown cable ID was created by juergen.scholl
While TIA stands for a photo-optical device to me this looks like a simple coupling, from 4mm to 2mm banana may be??
Could you post a picture of the metalic tip, is there something to be seen that reminds a sensing element?
Being a used item how about sking the previous owner/seller for details?
The following user(s) said Thank You: apache4trak
4 years 4 months ago #56586
Replied by Noah on topic Unknown cable ID
(T.I.A. Thanks In Advance
Funny looking thing, I thought nose hair trimmer, but probably not.
Let us know when you figure it out!
- oic5555
- Thank you received: 11
4 years 4 months ago #56617
by oic5555
Replied by oic5555 on topic Unknown cable ID
Hello,
Looks to be an adapter cable to go from a 4mm socket to a 2mm plug. Just picked one for the Power Probe breakout box to allow using a multi meter to connect to the breakout box that has 2mm connections to use the tips of a probe.
aeswave sells these under the part number 08-49-42. From their description: "Converts 4mm Plug to 2mm Plug.
Use this adapter when you need to need to connect your oscilloscope’s 4mm test lead/probe to a 2mm socket"
They have a video on their site showing this and one that goes the other way
Looks like what you have
The following user(s) said Thank You: Noah, juergen.scholl, apache4trak
