Re:Cylinder 4 misfire
- RayonG
3 years 10 months ago #59101
by RayonG
Cylinder 4 misfire was created by RayonG
- Ben
- Thank you received: 215
3 years 10 months ago #59102
by Ben
Replied by Ben on topic Re:Cylinder 4 misfire
What transducer are you using? I assume this is engine cranking its wide open throttle since we don't see an intake vacuum event (which is not ideal for much more than peak compression) ideally engine idling and snap throttle is where you will see issues. Lastly making a tool profile for the transducer to see psi rather than voltage will help to tell what is excessive leaking vs normal amounts but may bot be needed if the cylinder has major issues
- RayonG
3 years 10 months ago #59103
by RayonG
Replied by RayonG on topic Re:Cylinder 4 misfire
Thank you for replying. The throttle is closed. I am using a Rotkee ps16 pressure transducer. Calibration is a problem setting up from v to psi.
- RayonG
3 years 10 months ago #59104
by RayonG
i will also do a running capture
