Mitsubishi 3.8 Mivec V6 relative compression results analysis
  • Bhodges
  • Bhodges's Avatar Topic Author
3 years 7 months ago #60716 by Bhodges
Hello Everyone. I accidentally posted this in the repair section and can't find a way to delete it. I recently had diag done on an 06 eclipse gt mivec 3.8 V6 with a hard start, p0301 misfire when cold condition. Diag guy said to replace the maf sensor due to rich condition and possibility of bent valves. I'm posting the results here to see what others think. Engine misfires on cylinder 1 when cold outside and trips cel p0301. It sounds like a sticky lifter on cylinder 1 when you first fire it up and then the lifter tapping noise stops after a few seconds. Runs great when warm with no cel. It had the parts cannon thrown at it, plugs, coils, injectors and fuel pump by the previous owner trying to fix the misfire. Previous owner stated that he did not start experiencing this problem until he changed the timing belt. Is it possible that the timing is off a tooth ? This is a sohc 24v 3.8 V6 with variable valve timing.
3 years 7 months ago #60721 by Noah
I wonder if that relative compression waveform needs to be inverted. The ignition strike is taking place at the low points in the waveform, whick makes me think the tech used the voltage drop method instead of a current probe. Which is perfectly acceptable, as long as you either flip the pattern, or are just used to reading them upside down.
If that's the case, then the low portion of the pattern is where you need to look.
3 years 7 months ago - 3 years 7 months ago #60723 by juergen.scholl
I understand that the blue trace is showing intake manifold vacuum, I don't see it being relative compression..
There is more data needed to get to the root cause. Although the involved shop put time into this the excerpt of the report doesn't reflect a genuine diagnosis going beyond (partial) data recollection.
Last edit: 3 years 7 months ago by juergen.scholl.
3 years 7 months ago - 3 years 7 months ago #60728 by Noah
Hey, that makes sense! Good man Juergen!
That's what I get for skipping the words and going right for the pictures
Last edit: 3 years 7 months ago by Noah.
  • Bhodges
3 years 7 months ago #60734 by Bhodges
So this could possibly be misdiagnosed ?
3 years 7 months ago - 3 years 7 months ago #60735 by juergen.scholl
Possible? Yes, maybe.....
As stated earlier, more data needed..Missing when cold on one cylinder could be an intake air leak and might be recognized through the fuel trims. Was the intake been smoke tested?
Could you share the complete report?
