Oscilliscope recommendation for ludite
- idickers
The U-Scope is widely used in the industry with much praise.
I don't personally own one, but have used one. It's a good option for beginners, or even experienced techs that don't need to bust out the big guns.
It is a single channel, so if you want to to cam and crank relationship waveforms, you'll need to upgrade.
- idickers
- idickers
- Matts Auto
- Thank you received: 28
Maybe he will be kind enough to pop in here and give an honest review.
- idickers
Something like the MicSig SATO1004 might be worth the extra cost if it is reliable.
- Tutti57
- Thank you received: 254
I am the Migsig user Noah mentioned, and I do like it a lot, and would buy it again. Do you have any specific questions?
I also have a uscope that I still use often, but probably use the Micsig SATO 1004 most often. The one with the touch screen and buttons on the side. I like having the buttons and would probably not like the touch only as much.
It doesn't have isolated channels like the higher end PICOs, but I don't think you can beat it in this price range. Battery life is good. It feels very nice, and is heafty. I like very much that the battery is replaceble.
You can get a DC adapter that connects right to the car battery to charge it and the charge ground is connected to the lead ground, so while using the DC charger your neg lead is always connected to battery ground, which is cool. I haven't used it, but it has the ability to connect to a monitor or diplay if you want a bigger screen. I saw some videos where people complained about fan noise, but they must not be working in a shop, cause I can't hear it. Very easy to use interface. You can easily save captures and name them quickly with the tool.
The four channel option I used before this was the android based HScope, which requires a tablet or phone with 4GB of RAM and one of the approved budget scopes on the list at the bottom of this page. This makes the garbage Hantek software a non-issue. The software of this app is unbeleivibly good and is continually updated. Very feature rich and a huge buffer. It is not a standalone set up like the Micsig though, so I don't use it anymore. It's just easier for me to grab a standalone than set all of the stuff up, but for a low budget 2-4 channel setup, there is nothing close. You can do 2 channels for like $80 and 4 for less than $200.
www.martinloren.com/hscope/#media_gallery-3
The Autel was on my list too. I didn't know it has been discontinued. If I had a compatible scantool, I probably would have gotten it for the price, but didn't want to use my laptop.
- idickers
I am looking at the Hantek CC-650 and CC-65 current clamp meters. I have seen coil-on-plug probes, are those helpful over just backprobing?
- juergen.scholl
- Active partschanger
- Thank you received: 462
Current probes are great to have. Once you find scoping is for you then take it from there and get intersted in things like pressure transducers, supersonic probes, piezo sensors and all the other "weird" stuff that makes for a lot of fun.
- idickers
Is the increased resolution of a 12-bit scope a significant advantage in automotive diagnostics?
- juergen.scholl
- idickers
- juergen.scholl
You could measure across
one or more variable reluctance sensors (CKP, CMP) and battery negative referenced signals for example. With a common ground scope you could - worst case - cause a no start when grounding the CKP inadvertently.
On newer cars sensor grounds are often offsetted from chassis ground for noise reduction and floating grounds come in handy in these scenarios as well.
The ground isolation is a 'relative' thing...out of my head the pico automotive scopes with floating grounds are rated at potential differences up to 30V..
Though floating grounds are nice to have they are not necessary nor a big advantage on > 90% of automotive labsope diagnostics imo.
