Question about relative compression scope settings
- johnathon.balderas
- Stay humble and thank God everyday for waking up.
- Thank you received: 19
- Ncautoshop
- Thank you received: 6
What settings were you using? Are you using voltage or an amp clamp? What amp clamp is it?johnathon.balderas wrote: Was trying to setup my Uscope for a relative compression test. Had alot of trouble getting a clear picture. I tried my modis recently and also had trouble getting a clear picture. Any suggestions would be appreciated
Sent from my SM-G955U using Tapatalk
- EricGoodrich
- Thank you received: 49
- Dylan
- Belgium, Europe
- Thank you received: 327
- MuhammadAli89
- Willing to understand clear the Electronic Circuit
Low Amp Probe; 60Amp (10mV/1A) can be used with 20:1 Attenuator? or will have to use High Amp Probe; 1000Amps?
- EricGoodrich
MuhammadAli89 wrote: Yes 1000Amps setting is pretty ok for Relative Compression.
I use a 650A clamp for relative compression testing. My 80A clamp is too small to fit around the battery cables, usually. I have not tried using it for high amp testing.
