Low Amp clamp for scope
  • WrenchWizard88
  • WrenchWizard88's Avatar Topic Author
1 year 7 months ago #84386 by WrenchWizard88
Low Amp clamp for scope was created by WrenchWizard88
    Im looking into purchasing a low current amp clamp for a labscope I currently use and was wondering if anyone might have some insight as to which one to get or if someone can point me in the right direction please. I will be using it to diagnose injector and coil circuits as well as doing relative compression tests etc.
1 year 7 months ago #84405 by Noah
Replied by Noah on topic Low Amp clamp for scope
a.co/d/eFAuUvU
This is the one I use. I've had a few, I trust this one more some of the others I had.
It turns off automatically, which can mess you up if you're not paying attention when it happens, but it's pretty accurate.
The following user(s) said Thank You: WrenchWizard88
  • WrenchWizard88
1 year 7 months ago #84454 by WrenchWizard88
Replied by WrenchWizard88 on topic Low Amp clamp for scope
Also would you recommend a low current or a high current amp clamp lets say for doing a relative compression check and when conducting one what settings would you set the scope to for using the clamp?
1 year 7 months ago #84483 by Tyler
Replied by Tyler on topic Low Amp clamp for scope
Definitely recommend a high amp probe for relative compression.
You can do relative compression with the right low amp probe, but it's a pain. You're limited by the cranking current of the engine you're testing. The Snap-On low amp probe, for example, will max out at 200A. That means you can test most four and six cylinder engines. But some V8's will draw over 200A during cranking, and you won't see anything. Getting the small jaws of a low amp probe around the right battery cable can be a fight, too.
Most high amp probes will use a 1mV/1A scale. So, if your scope shows 150mV, you're measuring 150A. Most gas engines draw somewhere between 100-300A during steady cranking, so a 500mV or 1.0V scale will work well. Some scopes (Pico, Autel) have a preset probe at this conversion scale, some others (Snap-On) do not.
The time base will depend heavily on how much detail you're looking for, and what scope your using.
  • WrenchWizard88
1 year 7 months ago #84655 by WrenchWizard88
Perfect I am gonna get the high amp as well I appreciate the insight most definitely
Time to create page: 0.332 seconds
