Help with scope.
- david.rudling-smith
5 years 10 months ago #45519
by david.rudling-smith
Help with scope. was created by david.rudling-smith
Hi guys,
Was after some advice. Having previously wasted money on a scope (not really fit for purpose and wasn’t automotive specific) I was after some advice.
I work outside mainly on sites, mainly on cars and light vehicles sometimes on lorries and plant/agricultural.
I’m new to using a scope but put in a lot effort into learning and reading.
I would like a scope that is primarily easy to get and load(so ideally hand held) , robust (as I work outside in not so sunny uk(Wales)) and a good platform to learn from and advance in oscilloscope diagnosis!
One I had found was the
Draper 64573 - if people could give me there opinions on this and any alternatives Heres link
I had also thought about the the uscope but do like the idea of two channels.
Many thanks david
Many thanks david
- Matt T
- Thank you received: 276
5 years 10 months ago #45521
by Matt T
Replied by Matt T on topic Help with scope.
That Draper looks expensive for what it is IMO. Doubt it's much better than the Hantek 2D82 which is a lot cheaper.
eleshop.eu/hantek-2d82-auto-automotive-oscilloscope.html
For a bit less than the Draper the Micsig ATO1104 is worth a look.
www.telonic.co.uk/Micsig-ATO1104-Tablet-...ope-p/mi-ato1104.htm
Used Snap-on would be another option is the States but not sure about the UK??
5 years 10 months ago #45522
Replied by david.rudling-smith on topic Help with scope.
Thank you for the advice I like the look of both of those! What makes the difference in one being £500 more expensive? Apart from looks/4ch
Also with the hantek is the wave signal generator any good? Looks like you have to know the exact wave form to be able to use it? Compared to signal generators where they are preset
5 years 10 months ago #45523
Also what’s everyone’s opinion on the ditex carscope viso? Especially compared to micsig
- Matt T
5 years 10 months ago #45524
by Matt T
Main difference, aside from the obvious, is the Micsig has a very large buffer which'll let you record a fairly long capture then go back and review it. If you've seen videos of folks using the automotive Picoscopes it'll work similar to that. They do also offer a 2 channel but it's only 40 quid cheaper so I reckon it's better to have 4 for that little extra money.
The Hantek won't have much of a buffer so you'll be pretty much limited to what it shows on the screen in real time. It's basically a cheap 2 channel option if you'd like to spend a good bit less than the price of that Draper.
Re. the function generator that falls in the really cool but not all that useful category IMO. Pick the 'scope that's right for you without worrying about bells and whistles.
david.rudling-smith wrote: Thank you for the advice I like the look of both of those! What makes the difference in one being £500 more expensive? Apart from looks/4ch
5 years 10 months ago #45528
Thank you so much for your advice.
I do really like the look of the Micsig, what’s the main difference between that and a picoscope?
I set my self a tool budget of £800-1000 on tools for the next 6months and not sure if I want to blow the budget on one tool. However I also don’t want to buy the hantek and then in a years time also have to upgrade!
- DougS
5 years 8 months ago #46892
by DougS
Replied by DougS on topic Help with scope.
Hi David,
The main difference is the Picoscope is PC based. You will need to use it with a laptop PC. The Micsig appears to be completely self-contained. All you would need is to have the probes for the things you look at the most.
The Picoscope can be purchased in a kit that will have most everything needed to hit the ground running (except the PC!).
After looking at the Micsig, I would like to see it up close and personal to see what it can do and how it works.
Take care,
DougS
Take care,
DougS
