connections
  • nahulak3
  • nahulak3's Avatar Topic Author
5 years 7 months ago #47281 by nahulak3
connections was created by nahulak3
When connecting the Picoscope to measure crankshaft sensor which is an inductive sensor and both sensor wires goes to the PCM (+ and -). Which wire do you use to see pattern on scope?
5 years 7 months ago #47282 by Chad
Replied by Chad on topic connections
This depends on internal PCM circuit design. If the (-) is a true ground, the signal will be only on the (+) wire. IF the the circuit uses a "floating" ground, you will see a signal on BOTH wires, but the oscillations will mirror each other, rather than line-up/stack.
You can connect your scope a couple different ways. If you ground/reference your scope to battery (-), you can use two scope channels and watch both wires (Sensor (-) and (+) )at the same time. Or, you can ground/reference you scope the to the Sensor (-) and use a single channel on the sensor (+).
The following user(s) said Thank You: Noah, Andy.MacFadyen, nahulak3
Time to create page: 0.251 seconds
