Postive controlled PWM
- Mahdy
But the question is if it a PWM postive controlled device , is it being controlled derictly by the ECU ? Does the ECU has the ability to pull up to 12V ? (OR) the ECU regulates\pulsates the control side of a relay " negative side" which as a results pulsates the relay's output 12V ending to the device ?
I hope my question is clear
Relays, as electronic devices, usually don't respond well to pulse width modulation. :silly: The more their load side contacts are cycled, the more likely they are to develop high resistance, arcing, and eventually stop working correctly.
If the OEM's goal is to modulate magnetic field strength in a circuit AND make it out of the manufacturers warranty, they're much more likely to use a true positive side pulse width driver to make the magic happen.
Did that answer your question?
- Mahdy
So let's say can we control purge solenoid , fuel pump , fan motor by pulsing and controlling the postive side ?
Do ECUs have the ability to pull the circuit up by PWM ?
I know that most of the PWM controlled circuits are being pulsated to negative to be turned on , but can it be controlled by ordering the postive side to turn on and off ?
- Matt T
- Thank you received: 276
Tyler wrote: If I understand you correctly, you're wondering if a given ECU can pulse width control the negative side of a relay to positive side control an output (solenoid, motor, whatever). The answer is it's possible on paper, but you're very unlikely to run into such a setup.
Relays are electro-mechanical devices. Any electronics inside them are there for suppression. Physically moving the contacts takes time. A few milliseconds for both on and off. That would make for a very low PWM frequency which wouldn't be much good for motor or valve control.
Another issue is relays have a rated switching cycle life in the hundreds of thousands. That would get eaten up quickly at say 10Hz. Ran the numbers on 500,000 cycles at 10Hz and it comes out at just under 14 hours. Wouldn't even make it to the first oil change :lol:
That said it is possible to implement PWM control using solid state relays but I haven't personally seen it done in an automotive application. Or at least not obviously. Something like a GM blower motor control module may just be a solid state relay in a $100 box.
- Ben
- Thank you received: 215
