Pico current clamps on Snap on Verus
- Alexandros Vasilis
5 years 2 months ago #50497
by Alexandros Vasilis
Pico current clamps on Snap on Verus was created by Alexandros Vasilis
Got a snap on verus and searching for current clamps. I saw Scannerdanner use pico ones but the pico TA189 costs like 350 amd the pico TA009 costs like 100. Im still new at this but can i get away with the TA009 in fitment and practicality? Thank you to everyone for all the help in advance!
5 years 2 months ago - 5 years 2 months ago #50498
Replied by Andy.MacFadyen on topic Pico current clamps on Snap on Verus
Amp clamps are pretty generic, Pico sell good products the clamps in the Pico Economy range will do the job although they may give more noise in the output and drift more than the Premium range clamps.
They are certainly better than the Hantek
www.scannerdanner.com/tools.html
Last edit: 5 years 2 months ago by Andy.MacFadyen.
The following user(s) said Thank You: Alexandros Vasilis
- YOTA MDT
- Thank you received: 2
5 years 1 month ago #51701
by YOTA MDT
Replied by YOTA MDT on topic Pico current clamps on Snap on Verus
I have a otc low amp probe and a aes wave low amp probe both work well with my Verus Pro, The aes is about 100.00 the otc about 150.00 on Amazon. For high amps I use a Electronic specialties 1000 amp probe purchased from aes wave for about 100.00 it has banana jacks so it doesn't require adapters. both of the others do. One was supposed to come with the otc but didn't. all of these were purchased with cost in mind because I'm getting ready to add the Pico 4425-A to my arsenal. so for the money they seem to work okay You will need to do some math conversions to set them up
- YOTA MDT
5 years 1 month ago #51702
by YOTA MDT
I have a otc low amp probe and a aes wave low amp probe both work well with my Verus Pro, The aes is about 100.00 the otc about 150.00 on Amazon. For high amps I use a Electronic specialties 1000 amp probe purchased from aes wave for about 100.00 it has banana jacks so it doesn't require adapters. both of the others do. One was supposed to come with the otc but didn't. all of these were purchased with cost in mind because I'm getting ready to add the Pico 4425-A to my arsenal. so for the money they seem to work okay You will need to do some math conversions to set them up Don't let me steer you away from a more quality unit though. This is an area where you get what you pay for. If I was only going to have one clamp I would expect the Pico to be better than the others as far as quality of waveform and ability to zero out and not wander
5 years 1 month ago #51714
The easy way to do mV to amps conversion is draw straight line graph mV on the X axis then you can leave the scope on the mV scale.
With current clamps to get to know do a couple sanity checks on something you know roughly what the current should be on such as a 12v 5 watt bulb and 21 watt bulb.
5 years 1 month ago #51724
Replied by Alexandros Vasilis on topic Pico current clamps on Snap on Verus
Hey there,
thanks for the reply and the tips much appreciated, I ended up buying the pico economy ones but with bnc and i couldn't find them with banana and bought a bnc to banana converter so i can start slowly getting familiar with them! all the best man to you!
5 years 1 month ago #51725
Hi there,
thanks for the tip! will do and try out to get familiar with different circuit current and the set ups! Much appreciated for the info and the support man!
