2011+ F Series issues to take into account
  • Ncautoshop
  • Ncautoshop's Avatar Topic Author
8 years 11 months ago #14702 by Ncautoshop
2011+ F Series issues to take into account was created by Ncautoshop
We've been seeing some very common issues with the new F-series trucks that's worth mentioning.
1: 6.7l battery cables shorting to ground at passenger side of engine/cross member. It WILL start a fire.
2: HS Can high issues - waveform is neither shorted to 12v, 5v or ground and the issue may be extremely intermittent. The variance is very slight but enough to pull communication down. Many trucks have spent months at the dealership with no resolution. The one fix that has been consistent is removing the bundle connector from the e-brake bracket and zip tying it up. There's never any resistance issues, pin damage or wiring faults from my experience - I'm almost wondering if it's not related to the harsh "smack" when the brake is released.
Hopefully this will help someone.
Sent from my SM-G955U using Tapatalk
8 years 11 months ago #14727 by Tyler
Replied by Tyler on topic 2011+ F Series issues to take into account
I've seen HS-CAN issues on these trucks as well. Fixed a couple by cycling those bulk connector by the parking brake pedal.
Never seen the shorted cable. O_O Gotta keep an eye out for that!
  • Ncautoshop
8 years 11 months ago #14745 by Ncautoshop
Replied by Ncautoshop on topic Re:RE: 2011+ F Series issues to take into account
Tyler wrote: I've seen HS-CAN issues on these trucks as well. Fixed a couple by cycling those bulk connector by the parking brake pedal.
First instance was a dealer truck thst had floated around the local shops. I noted that I didn't have sensor ground for the oil temp & a/c pressure or the rest of the grounds in the circuit. My initial testing found that there wasn't ground being supplied from the PCM, and i suspected a faulty pcm. I decided to patch in a ground to see if it would bring the affected circuits back to life, when I touched the ground it blew my jumper fuse. I had one of my tech's pull the loom down, and he was having trouble with a bolt for the plastic retainer. I reached up to put some pressure on the plastic to aid in removal and got a spark shower. We've seen 4 like this thus far!
The following user(s) said Thank You: Andy.MacFadyen, graywave
8 years 11 months ago #14759 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Re:RE: 2011+ F Series issues to take into account
Ouch ! not good :S
The following user(s) said Thank You: Ncautoshop
8 years 11 months ago #14767 by Noah
Wow, thanks for the heads up man!
Time to create page: 0.322 seconds
