The 100Hp 6 cylinder Mercury Outboard continued
10 years 1 month ago - 10 years 1 month ago #2105
The 100Hp 6 cylinder Mercury Outboard continued was created by Andy.MacFadyen
Continued from old forum. the job turned out to be easier than expected, we managed to find NGK spark plugs equivalent to the original Champion J4J cleaned out the 6 Tillotson carburettors, fresh 2 stroke mixture and it fired it up ---- on 3 cylinders
There was a good spark at both coils but not at 3 of the plugs. The ignition is an odd ball system 2 coils each providing a spark for 3 cylinders but only one distributer cap. The distributer has two king leads, one comes in from the side into of the cap via a fitting held by 2 screws. Removing this fitting revealed the problem the carbon brush was broken. I salvaged a carbon brush from an old Lucas distriubuter cap cleaned the distributer out and it was back purring on all 6 cylinders.
The owner inherited from his dad and hasn't got a test tank or a cooling water adaptor so we could only run it for less than a minute without letting it cool but it was sweet --- real quality engineering.
Last edit: 10 years 1 month ago by Andy.MacFadyen.
10 years 1 month ago #2107
Replied by Noah on topic The 100Hp 6 cylinder Mercury Outboard continued
Awesome, I was wondering if you ever got into with that beast. I had never seen one until you brought it up, so I googled it. Pretty cool engine, glad you got it straightened out.
Time to create page: 0.243 seconds
