Reapring/gluding engine cover plastic panels
- JeffBirt
- Thank you received: 34
8 years 3 months ago #22004
by JeffBirt
Reapring/gluding engine cover plastic panels was created by JeffBirt
Has anyone every found a way to glue/repair an engine cover (plastic) panel. I have one that has mounting foot broken off. I can fabricate a new foot but I'm wondering if there is an adhesive that will bond to the plastic they make these out of (2005 Escape V6). If nothing else I guess a mechanical fastener can be sued to secure a fabricated mounting foot. There is no point in looking at a junk yard as I suspect all of them have broken in the same place.
Thanks!
Thanks!
8 years 3 months ago #22006
Replied by Andy.MacFadyen on topic Reapring/gluding engine cover plastic panels
No eBay APP ID and/or Cert ID defined in Kunena configurationI think the material A.B.S. I am not sure how good a bond you would get with 2 part expoxy, in the past I have used a long nut called a stud joiner and large "penny" repair washer
8 years 3 months ago #22007
- Tutti57
- Thank you received: 254
8 years 3 months ago #22010
by Tutti57
Replied by Tutti57 on topic Re:Reapring/gluding engine cover plastic panels
You can try Q-bond. It's not cheap but it works pretty well on plastics. It's basically super glue with hardening powder.
8 years 3 months ago #22016
Replied by Tyler on topic Re:Reapring/gluding engine cover plastic panels
You have a first gen Escape that still has the engine cover? :blink: Amazing!
I like two part epoxy, personally, but it takes time to set up. Glue it up and let it set overnight.
8 years 3 months ago #22044
Replied by Noah on topic Re:Reapring/gluding engine cover plastic panels
I have successfully "soldered" my plastic glasses frames with a soldering iron using a black plastic zip-tie as solder.
I'm also quite fond of silicone gasket maker to glue things to other things. It holds great, is chemical, heat and vibration resistant, yet you can remove it whenever you're ready.
I'm not sure if either is a viable option for you.
- vb4me
8 years 3 months ago #22258
by vb4me
Replied by vb4me on topic Re:Reapring/gluding engine cover plastic panels
If it is abs then you can glue an abs part to it with acetone. Just coat both parts and join together. For a stronger bond "melt" some scrap or shavings of abs into the acetone then apply like a paste.
- PDM
- Thank you received: 56
8 years 3 months ago #22403
by PDM
Replied by PDM on topic Re:Reapring/gluding engine cover plastic panels
I second Q bond. A cheaper alternative is something I use regularly. Super glue and baking soda. Search for Sweet Project Cars on Youtube. He has a video on repairing plastic this way
