Inrush current flow
  • al514
  • al514's Avatar Topic Author
6 years 6 months ago #39362 by al514
Inrush current flow was created by al514
So I recently watched a video on inrush current, the current flow that is initiated when , for instance, a lightbulb circuit is first turned on. On some bulbs it can 4 times the rated current of the bulb. Does it not pop a fuse because the overflow is so short?
6 years 6 months ago - 6 years 6 months ago #39365 by Chad
Replied by Chad on topic Inrush current flow
The fuse doesn't blow because the high-current inrush doesn't last longer than a few milli-seconds. Light bulbs have a "Positive Temperature Coefficient". When the bulb is cold resistance is at its lowest, and current is at its highest. As soon as the bulb is energized, it heats up. Resistance increases and current decreases. This happens so fast that the fuse, for lack of better words, doesn't have time to blow.
www.facebook.com/ScannerDanner/videos/249487746209469/
Last edit: 6 years 6 months ago by Chad.
The following user(s) said Thank You: al514
  • al514
6 years 6 months ago #39371 by al514
Replied by al514 on topic Inrush current flow
Thanks man, I figured there was a logical answer out there. I did see how fast the bulb heats up. It was like half a second or less. So that all makes sense.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
6 years 6 months ago #39399 by Dylan
Replied by Dylan on topic Inrush current flow
Was this the video from Rob Dotterer you watched?
