Brandon Steckler full Class Online 6-22-20
  • John Curtis
  • John Curtis's Avatar Topic Author
6 years 4 months ago #40764 by John Curtis
Brandon Steckler full Class Online 6-22-20 was created by John Curtis
us02web.zoom.us/webinar/register/WN_Rc8kwmPSTG24HxkGqEQ54A
Above is a registration link for Brandon Stecklers full Pressure waveform analysis class.
It begins 6-22-20 and will be 4 days of 2 hour classes. Be sure to register!
6 years 4 months ago #40829 by Noah
Thank you for posting that link.
Part one was very well delivered last night, ready for Wednesday!
6 years 4 months ago #40833 by juergen.scholl
Replied by juergen.scholl on topic Brandon Steckler full Class Online 6-22-20
Noah wrote: Thank you for posting that link.
Abdolutely true.
Best thing about it: It only will become BETTER!
  • John Curtis
6 years 4 months ago #40842 by John Curtis
Replied by John Curtis on topic Brandon Steckler full Class Online 6-22-20
Hope we all learn a whole lot with tonight’s class! I had an interesting misfire for me to deal with yesterday.
I did an RC TEST with a sync and an intake pulse because I had low contribution on cylinder 4 on a 4 cylinder engine.
I didn’t see anything that struck me as odd with the intake pulse so I decided to clamp the PCV and check the crank case. The compression loss directly correlated with a pressure spike in the crank case which repeated itself every time. Within 20 minutes, I was able to know with 100% confidence that the customer was needing a new engine. All of this using a $0.50 piezoelectric disc and a couple plumbing fittings. Not having a transducer is a blessing because it’s forcing me to learn this.
6 years 4 months ago - 6 years 4 months ago #40843 by juergen.scholl
That's quite interesting. Blow by testing in the crank case I've found little conclusive unless it was a really gross fault though.
I take it you checked crank case pressure with the engine running. If so was it already spotable at idle and did it show up worse at higher rpm?
Last edit: 6 years 4 months ago by juergen.scholl.
  • John Curtis
6 years 4 months ago #40844 by John Curtis
It was indeed running. The problem was a dead miss under all conditions, just didn’t feel quite as bad at higher RPMs. I did not check with a borescope but my theory was a hole in the piston.
I’ve also used the delta sensor on the cooling systems quite a bit and you can see when the water pump functioning with it.
6 years 4 months ago #40846 by Matt T
Replied by Matt T on topic Brandon Steckler full Class Online 6-22-20
John Curtis wrote: I’ve also used the delta sensor on the cooling systems quite a bit and you can see when the water pump functioning with it.
Have you found any pump impeller problems with it?
  • John Curtis
6 years 4 months ago #40848 by John Curtis
Not yet! I believe it is possible, but I also think that there’s a real possibility of too much turbulence to really know for sure.
Time to create page: 0.406 seconds
