2000 Nissan Xterra Delayed engagement
  • Tyler's Avatar Topic Author
9 years 6 months ago #8673 by Tyler
#ecwurban
I find that temperature related symptoms almost always ends up with an internal transmission problem. :-( Pressure seals can leak when cold, but seal up when warmer. Or, worn clutch packs can slip cold but grab once the fluid temperature rises.
There's also the known issue with the trans fluid getting contaminated with coolant via the fluid cooler in the radiator. How did the fluid that came out look?
9 years 6 months ago #8689 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2000 Nissan Xterra Delayed engagement
I have never been a bit fan of JATCO transmissions I don't know if this sheds much light etereman.com/blog/nissan-transmission/is...op-should-know-about
