2011 Chevy Volt. No Communication to Engine, Transmission after replacement.
  • Eli
  • Eli's Avatar Topic Author
4 years 4 months ago #56740 by Eli
I have a 2011 chevy volt in the shop. Replaced the transmission. Now I'm getting no communication with the Transmission, The engine, the ABS, and the HV Battery. I have codes U0100, U0101, U0121, U1515, U1534, U153A. I'm thinking there may be a reset needed after performing this procedure? Pro demand has very little helpful information for these codes. Any advice is appreciated.
Thanks,
Elijah McMillan
4 years 4 months ago #56752 by Cheryl
Might want to check all grounds. Check for 60 ohms at dlc pins 6 and 14
4 years 4 months ago #56753 by Cheryl
You will have to check at the ecm because you have a gateway module
4 years 4 months ago #56754 by Cheryl
There is a gound g113 says it’s on the rear of the transmission in the location on Mitchell
  • Eli
4 years 4 months ago #56762 by Eli
Pcm has power and ground. I have 120ohms between pin 6 and 14 of the DLC. Also 2.4Kohms between both 6 and 14 and pin 4 (ground) I'm assuming this indicates a short to ground? Where would you go next"
4 years 4 months ago #56763 by Cheryl
You checked all powers and grounds? That test at the dlc not accurate since there is a gateway module. Got a 5 volt reference?
  • Eli
4 years 4 months ago #56764 by Eli
Thanks for warning me about the accuracy of the DLC test. When you say "all powers and grounds" do you mean all PCM powers and grounds? or all module powers and grounds?
4 years 4 months ago #56765 by Cheryl
Pcm power and grounds. All of them
  • Eli
4 years 4 months ago #56766 by Eli
According to the connector pinouts, the PCM has one power and one ground. Both a good.
4 years 4 months ago - 4 years 4 months ago #56778 by Tyler
Is there a gateway module on this Volt? I can't find one in service info. :huh:
I'd go direct to the EBCM, if it's halfway accessible. It's the next module in line, going from the DLC to the ECM.
Ignition off for two minutes, ohm between 37 and 24 (towards the DLC), then 36 and 23 (towards the A/C Compressor). A good reading would be 120 ohms in both directions. But, your readings at the DLC indicate an open, so hopefully one direction will show open.
If the EBCM isn't accessible for testing, do the same test at X190 instead.
Last edit: 4 years 4 months ago by Tyler.
4 years 4 months ago #56784 by Cheryl
Maybe I had the wrong year but the Mitchell drawing had pins and 14 going to the bcm then out of the bcm to the rest of the modules.
  • Eli
4 years 4 months ago #56786 by Eli
Tyler, Thanks for the response. I found and open in the Power Steering Module of all places. I will update everyone when the problem is fixed (parts ordered)....
  • Eli
4 years 4 months ago #56787 by Eli
It seems I don't have a gateway module, I really appreciate your help with the troubleshooting process. I will update you when the part arrives.
4 years 4 months ago #56789 by Tyler
Really? :huh: I don't doubt you, but that's a bit surprising. Since the EBCM is upstream of the PSCM (relative to the DLC), I'm not sure why you'd have U0121 Lost Communication With EBCM. Did you happen to try communicating with the EBCM directly?
However, I'm happy to be wrong if it fixes the car! :cheer:
  • Eli
4 years 4 months ago #56798 by Eli
Tyler,
I did try to communicate to the EBCM and was able to communicate with it.... I'm hoping I didn't miss something key in my diagnostics...
4 years 4 months ago - 4 years 4 months ago #56799 by Tyler
Tyler,
No no, not at all! Not trying to introduce doubt. :blush: I probably should have asked that earlier. If I had, I would have changed my recommendation to skip testing at the EBCM and X190. But you were way ahead of me anyway. :silly:
  • Eli
4 years 4 months ago #56800 by Eli
I will update you with the results after I receive the new PSCM. I'm learning more every day.... and I love the challenge!
  • Eli
4 years 4 months ago #56865 by Eli
Update! CAN Bus is working!!! The New Power Steering Control Module Fixed the open in the CAN Bus. The schematics and advice you all shared were priceless with this diagnostic!
However, Upon powering on the car, It tries to start the engine and shakes violently. I'm really frustrated by this car, but I realize the only way to become a better tech is to push forward. Any Advice regarding this is appreciated. especially if someone has experience with the Volt Specifically.
Elijah,
2nd Mile Repair
  • Eli
4 years 3 months ago #57156 by Eli
Fixed!!!
I condemned the used transmission and got another…. Car is done! Customer is happy!
Thanks everyone,
Elijah
Time to create page: 0.373 seconds
