2008 Chevy Duramax LMM Overheating (mysterious blockage?)
  • Eli
  • Eli's Avatar Topic Author
4 years 4 months ago #56834 by Eli
2008 Chevy Silverado Duramax LMM. Overheats after about 1 mile of driving. Had a new water pump before it came to my shop. I did a dye test and am not detecting a combustion leak. So I put new thermostats in it. Condition still present.
Is there a better way to test for head gasket failure on these engines? I want to be 100% sure before selling the customer a 30hour head gasket job.
Is there some other element I'm Missing?
It almost seems stupid to ask about an overheating problem, but I know a lot of you have been in the field longer than I've been alive! Your advice is greatly appreciated!
Thanks!
4 years 4 months ago #56846 by juergen.scholl
A pressure pulse sensor placed over the open radiator or coolant reservoir while the engine is running would show pressure escaping from a cylinder into the cooling system.. Another option is to pressure test the cooling system, if necessary over night and then watching out for a hard start/vapor.
Driving just one mile is really quick for an engine to already overheat severely.
