Chrysler 300 V6 3.5 L 2010Touring edition no crank Key fob not resp/Reddit on cl
  • vanessa.martin
  • vanessa.martin's Avatar Topic Author
4 years 3 months ago #57111 by vanessa.martin
OK so I have a Chrysler 300 V6 3.5 L touring edition it’s a 2010 ran out of gas on the road put gas back in the vehicle tried to start it and it would start up several times and then go back out now it’s not recognizing key fob in the start position only in on position I bypassed the ignition and I can bump started with the fuse relay where the fuse was it started 34 times and died out also there is a red dot light on my cluster that was not there before and I believe should be going out after 15 seconds of putting the key fob in the ignition home please help seems like engines locked up radio does not work lights work doors work windows work took ignition apart in the ignition column where you plug it in and there’s a prong or two that are very wobbly and loose not even sure if they’re soldered in could this be the issue do I need to reprogram the key please somebody help I’m on the side of the street for a week and a half now and I need some help thank you
