C1187 2005 titan
  • Cheryl
  • Cheryl's Avatar Topic Author
4 years 3 months ago #57161 by Cheryl
C1187 2005 titan was created by Cheryl
Does anyone have any information on this code?? I can’t find anything on mitchell
  • Cheryl
4 years 3 months ago - 4 years 3 months ago #57165 by Cheryl
Replied by Cheryl on topic C1187 2005 titan
You have a wiring diagram for it to??
Last edit: 4 years 3 months ago by Cheryl.
4 years 3 months ago #57175 by Tyler
Replied by Tyler on topic C1187 2005 titan
Which module is setting this code?
From Mitchell:
Cheryl, check your PM's. ;)
  • Cheryl
4 years 3 months ago #57181 by Cheryl
I added a pic to the thread. It was in the abs module snap on scanner says did module no good. You ever see this code before?
4 years 3 months ago #57183 by Tyler
Negative. But I see new stuff all the time. :silly:
Probably Captain Obvious, but I wouldn't take the code description at face value. It sounds more like something that should have been a U-code...
  • Cheryl
4 years 3 months ago #57184 by Cheryl
That’s what I was thinking
4 years 3 months ago #57202 by Matt T
Replied by Matt T on topic C1187 2005 titan
OE documentation ain't the greatest but this appears to be a comm code indicating a problem between ABS and the diff lock control module over CAN. Diff lock diagnostics are K-Line so the fact you can talk to that module wouldn't mean much.
If you ain't already a member of nicoclub dot com you might want to join ;)
  • Cheryl
4 years 3 months ago #57228 by Cheryl
Tried another scanner. Found another code for a dif lock control switch. Was hard to find a wiring diagram on mitchell but accidentally found the factory wiring diagram. Found the lock switch wiring was melted on the tail pipe. Fixed code went away
