FORD PATS problem
  • Batdrest
  • Batdrest's Avatar Topic Author
4 years 3 months ago - 4 years 3 months ago #57191 by Batdrest
FORD PATS problem was created by Batdrest
Hello guys
I have Grand Marquis 2011 I they change the engin after that it dosn't crank becuse of the PATS system and the security light is blinking. I read the fault it's B1601 and I try all the 3 keys and the same code . And I try to erasa and program the keys I get message procedure Unsuccessfully. Also,I try used PCM & ANTNNA THE SAME.
Any body have an idea?
Last edit: 4 years 3 months ago by Batdrest.
4 years 3 months ago #57194 by Cheryl
Replied by Cheryl on topic FORD PATS problem
Does the cel illuminate key on engine off? Maybe a ground for the pcm was left off
4 years 3 months ago #57198 by Tyler
Replied by Tyler on topic FORD PATS problem
+1
Which module set the B1601? Does the scan tool communicate with the PCM?
  • Batdrest
4 years 3 months ago #57211 by Batdrest
Replied by Batdrest on topic FORD PATS problem
Yes it's blinking
  • Batdrest
4 years 3 months ago #57212 by Batdrest
The pcm set the code.
4 years 3 months ago #57213 by Cheryl
Can you access pcm and look how many keys are programmed? May be in the cluster as some fords are but you need to find out if there is any programmed keys
  • Batdrest
4 years 3 months ago #57216 by Batdrest
Thank you Cheryl for your help.
There are 2 keys stored in the pcm.
4 years 3 months ago #57220 by Cheryl
Almost seems like the transceiver is bad if there’s 2 keys already stored in the pcm or bad key. Maybe try getting 2 new keys from the dealer and try program them or a transiever module
  • Batdrest
4 years 3 months ago #57221 by Batdrest
Also I change the transceiver but the same. So will try to program another key and see what will hapen.
4 years 3 months ago #57235 by Tyler
Gotcha. If that's the case, then I'd suggest getting two new keys cut and using the Erase and Program function in PATS.
There isn't an old key zip tied to the PATS tranceiver, right? :silly:
4 years 3 months ago #57377 by Cheryl
You ever get it figured out?
4 years 3 months ago #57412 by Dtnel
Replied by Dtnel on topic FORD PATS problem
Just saw this. When the engine was swapped did the original PCM/ECM stay with the car or did a PCM from where the engine came from get installed in this vehicle with the engine?
I want to post this then look at more info as for example the early 2000's F-150 trucks, some people thought they didn't have immo but the heritage, HD edition and any others specified actually do have it as my understanding was ur was a higher trim level so it came with better options at the time.
I figured this out one day when called to a f-150 where another shop, 60+ yrs in business had been there 3-4 times and told him over and over there was no security.
I went to the car, turned the ignition with the metal key and as soon I turned it I knew what the problem was as it, the security light was flashing.
Got 2 chip keys, programmed them in and all was good.
Even stopped in a couple months later about 2 weeks ago and asked the owner how it was doing while he gave me a haircut and he said it's ran with no issues since then.
4 years 3 months ago - 4 years 3 months ago #57413 by Dtnel
[/quote]
IF you tried a used PCM did you use a scan tool and do a PMI so the system knows that the PCM was swapped?
Also keep very close track of everything you're dough as it potentially could save you some $$ if someone else has to come in and look at it as the less they know the more time they'll have to spend and ultimately the more they'll charge.
Last edit: 4 years 3 months ago by Dtnel.
4 years 3 months ago #57414 by Dtnel
What type of scan tools, programmers do you have?
