2004 Mazda 3 BK 1.6
  • Edward9637
  • Edward9637's Avatar Topic Author
4 years 3 months ago #57357 by Edward9637
2004 Mazda 3 BK 1.6 was created by Edward9637
I have a no communication, 5V reference wire is 11 Volts, guages go erratic, Odometer stays on when car is off, fuel pump gets constant power and, it only runs a few seconds after starting and sounds like a bulldozer with the flu.
Someone tried to jump the Intake Shutter Value Solenoid by connecting to the purge solenoid and also, there are 2 wires near the passenger headlight not connected.
When I returned to the Philippines, I found wires broken and hopefully, fixed them properly. I also found 2 old codes about the EGR solenoid valve and a bad O2 sensor.
I only have basic tools here and can not afford to take the car to Mazda to have it checked due to my daughter's transplant surgery.
I don't want to believe the PCM is cooked due to the fuses being popped.
Any direction at all would be a big help.
4 years 3 months ago #57359 by Chad
Replied by Chad on topic 2004 Mazda 3 BK 1.6
High voltage on the 5 Volt REF could be caused by a bad PCM GROUND. Or, a short to POWER. Coupled with the other electrical weirdness that you are seeing, I would check GROUNDs, first. Starting at the PCM.
  • Edward9637
4 years 3 months ago #57360 by Edward9637
Replied by Edward9637 on topic 2004 Mazda 3 BK 1.6
Thank you Chad. I have no communication but, when I back probed the PCM sensor ground wire to the negative terminal on the battery, It shows a voltage of .30.
One other thing.....I can not start the car unless I disconnect both sensors on the Throttle body, i.e., TPS and TS. I am not sure where to go from here? I have no idea where the ground strap for PCM is located.
I really want to thank you for your response.
