Ford 5.4 shuts off when hot
- Slomechanic
4 years 3 months ago #57459
by Slomechanic
Ford 5.4 shuts off when hot was created by Slomechanic
Hey everyone, I’ve been stuck on this f250 5.4 2004. Original issue was p0171 p0174. Replaced intake manifold gaskets due to vacuum leak.now truck has no cel and shuts off when hot after driving 45 min+.
When it’s about to shut off it’s like it has a vacuum leak, performed smoke test.leak test passed.fuel pressure is within spec.
LTFT 1: - 0.78% at idle
LTFT 2: - 0.78% at idle
MAF: 7.14 g/s
Barometric pressure: 156.59Hz
when truck starts to shut off. LTFT bounce from -8 to +8
Cleaned throttle body,no misfires.
Truck only shuts off after driving up to temp never cold. I’m stuck and I just need some advice. Thank you all for your help.
MAF: 7.14 g/s
- Cheryl
- Thank you received: 215
4 years 3 months ago #57463
by Cheryl
Replied by Cheryl on topic Ford 5.4 shuts off when hot
Does it stall like the key is shut off? Or like it’s running out of fuel type stall
- Slomechanic
4 years 3 months ago #57464
by Slomechanic
Replied by Slomechanic on topic Ford 5.4 shuts off when hot
Like the key is shut off.
- Cheryl
4 years 3 months ago #57465
by Cheryl
I’d make sure you aren’t losing power to the injectors or coils.
- Slomechanic
4 years 3 months ago #57471
by Slomechanic
Just hooked up and saw codes p1132 & p1152
