Crank No Start, Hyundai Elantra HD 2010 1.6L DOHC Gasoline Engine
  • UMOAWAD
  • UMOAWAD's Avatar Topic Author
4 years 3 months ago - 4 years 3 months ago #57513 by UMOAWAD
Hello there,
So, my car cranks but won't start. No codes, but the ECM shows readings of 3000 rpm, 51.76% throttle position, and 80 degrees celsius coolant temperature. needless to say that the fuel pump doesn't work when the ignition is turned to the 'ON' position. I checked the CKPS and ECT sensors for resistance and they were at specs. The readings remain the same when I unplug these sensors. The 5V reference is there. The Check Engine Light is not on when the ignition is on.
Where do I go from here ?
Thanks.
Last edit: 4 years 3 months ago by UMOAWAD.
Time to create page: 0.251 seconds
