Toyota yaris extended cranking time intermitent
- dzof
Is it normal that the fuel pump is activated (2, 3 second) after you shut the engine OFF?
With a Scan Tool I can activate the pump, I can here the relay and the pump being activated.
In an extend crank time the status Of the pump is OFF, then ON and the engine start.
Thank you
- bruce.oliver
- Thank you received: 88
- dzof
Don't have any issue while driving, I performed the test wide open throttle and the o2 goes rich.
the problem is intermittent .
- bruce.oliver
dzof wrote: Is it normal that the fuel pump don't start when ignition is ON and engine OFF,?
No, that's actually somewhat typical of Toyota. Most I've seen do NOT use a key on fuel pump prime, they just start running the pump during cranking.
Possibly? I haven't seen that, personally, but it may be normal.
It might be valuable to back up what the scan tool is saying with a test light on the fuel pump relay during the extended crank time. Not sure what year of Yaris this is, but I picked an '07 as an example:
Find this C/OPN relay, and connect your test light to the relay ground control pin I marked. Hook your test light up to B+ so that it lights when it finds a ground. Observe the light during normal cranking, and how quickly it comes on. Then watch it during your extended crank time, and see if it isn't getting lit as quickly.
If the test light lights normally, then the fuel pump control isn't an issue. If there's a lot of cranking before the test light illuminates, then we can go towards why the pump isn't getting commanded on correctly (possible cam/crank issue like bruce.oliver mentioned).
- dzof
thank you
- dzof
- dzof
- matt.white
- Thank you received: 29
Has the fuel gauge you have got a tap? One way of isolating the leak is to prime th system and quickly turn the tap off and see of the pressure still drops.
- dzof
so I connected the gauge directly to the pump the result was
prime: 2.5 bar
after 3 minute -> 2.3 bar
Then I connected the Injectors with a T pipe
Prime: 2.4 bar
after 3 minute -> 1,9 bar
I don't know If I can use simple math but
the pump lost 0.2 bar pressure in 3 minute
the injector and the pump lost 0.5 bar in 3 minute.
So I think I have leak in the pump and the injector.
Add to that I have a negative Lft -6 and Lft -4 at idling
I have white smoke in cold start. So I think I can confirm a leak injector and pump.
what do you think?
dzof wrote: Thanks Matt.white,
prime: 2.5 bar
Prime: 2.4 bar
what do you think?
For me, the easiest way to confirm a leaking injector would be to remove the fuel rail from the intake and leave the injectors installed in the rail. Prime the rail to full pressure (with the fuel line still connected to the rail), and place some tissue paper beneath each fuel injector nozzle. The one that's wet after 10 minutes or so is the issue.
Based on the pressure leak down rates you saw, I'd be inclined to go after an injector first, and recheck for a pump issue afterwards.
- matt.white
Is the fuel pressure regulator on the fuel rail on this engine ?
- dzof
- dzof
dzof wrote: thank you, I did the test and the four injectors are leaking
No joke! That's crazy, I'd have never expected all four to be leaking. :ohmy:
Let us know how the leak down test goes after replacing the injectors?
- matt.white
Be sure to do the filter after the injector leak is rectified anyway.
