Re:2014 Subaru Outback 2.5 (P0171) Lean Condition
- jman26063
- Thank you received: 2
4 years 2 months ago #57826
by jman26063
2014 Subaru Outback 2.5 (P0171) Lean Condition was created by jman26063
Good morning all, Helping a neighbor out here (or trying to not send him down the parts hole)??. Car has P0171 lean and has been to his shop twice. about 6 months ago they changed the MAF (Aftermarket) which he says solved problem for a few months. Happened again and he went back to this shop where they replaced both 02’s(aftermarket) and cleared code. He drove off and light back on! Came to me. Aftermarket MAF seems to report slightly low but did have a known good oem and swapped with no change in trims. LT is pegged at 27 - 29 and short term does not really make much correction. MAF hovers just under 2g/s with known good between 2 and 3 g/s. With known good no change in trims. Rear O2 is pegged rich. No vaccumn leak detected (water method only) will smoke soon. Trims slightly improve under load, but not much. LT to about 11 and short term moves a little. Im reading through the Danner Book? but trying to wrap head around the lean condtiion with pegged rich rear o2. Could I be dealing with bad new parts? Thanks community
- binglebee
4 years 2 months ago #57832
by binglebee
Replied by binglebee on topic Re:2014 Subaru Outback 2.5 (P0171) Lean Condition
so the LTFT will go from 25-29% at idle RPMS (what RPM?) to 11% under throttle (also what RPM?)
At first glance this bit of information does indicate a vacuum leak. or potentially a fuel delivery/pressure issue. the rpms you're seeing this at could help give a better picture
- jman26063
4 years 2 months ago #57833
by jman26063
Replied by jman26063 on topic Re:2014 Subaru Outback 2.5 (P0171) Lean Condition
Thank you for reply, I actually just did a better data recording test drive and at WOT LT drops and ST raises and fluctuates making me thing fuel. I will attach screenshots of graphed data so you can observe as well
- jman26063
4 years 2 months ago - 4 years 2 months ago #57834
by jman26063
Here are some recorded data graphs, WOT is between around frames 35 to 70. You can see the LT drop down B2 o2 does go rich but fluctuates slightly.
EDIT: Images were blurry colors are as follows
IMAGE 1
Blue- Load
Orange- RPM
Purple- LT Trim
Yellow- B1S2 Volts
IMAGE 2
Blue: B1S1V
ORg: ST Trim
IMAGE 1
Blue- Load
Orange- RPM
Purple- LT Trim
Yellow- B1S2 Volts
IMAGE 2
Blue: B1S1V
ORg: ST Trim
Last edit: 4 years 2 months ago by jman26063.
Time to create page: 0.363 seconds
