PCM
  • dmac7272
  • dmac7272's Avatar Topic Author
4 years 2 months ago #58006 by dmac7272
PCM was created by dmac7272
Just wanted to see if anyone has ever encountered this issue. I've got a 2009 Chrysler Sebring 2.4L that starts and runs fine, but after a few minutes it starts missing on cylinder 1. I can turn the vehicle off and re-start it immediately and the miss is gone, until it runs for a few minutes and starts missing again. Each time the miss is corrected by simply turing off the engine and then re-starting. I traced the fault back to the PCM. When the engine starts to miss, the driver/trigger from the PCM drops out (PCM is no longer sending signal to #1 coil during the miss). PCM replacement? Thanks
4 years 2 months ago #58010 by Cheryl
Replied by Cheryl on topic PCM
Did you current ramp the coils make sure amperage is all the same on the coils? But pcms will never turn off the coils but injectors it will
