2009 Pontiac G6 GT Transmission solenoid testing ?
  • Chad1974
  • Chad1974's Avatar Topic Author
4 years 1 month ago - 4 years 1 month ago #58213 by Chad1974
I have G6 that was running fine and it just started to slip from a take off with no warning. Right now i tested the 1-2 and 2-3 shift solenoid valve doing a ohm test and they were within range of 19-24 testing at 22.5 on both. The Torque converter Clutch pulse with modulation solenoid valve tested at 12.5 ohms and spec for this solenoid is 10-11 ohms. There are no ecm codes or engine light on. Was wondering if that 1.5 ohms over is maybe the cause of a partially failed valve causing the problem? I am testing these by disconnecting from transmission module and back probing. FYI i'm a dyi mechanic who is taking the scannerdanner course to learn testing before throwing parts at stuff. Thank You, Chad
Last edit: 4 years 1 month ago by Chad1974.
4 years 1 month ago - 4 years 1 month ago #58216 by juergen.scholl
Replied by juergen.scholl on topic 2009 Pontiac G6 GT Transmission solenoid testing ?
Without further details/evidence I wouldn't be concerned about the measured resistance. The value looks close enough and the deviation from the reference may well be due to the meter accuracy itself, probes and/or test leads, temperature....
Last edit: 4 years 1 month ago by juergen.scholl.
The following user(s) said Thank You: Chad1974
4 years 1 month ago #58225 by Tyler
Agree with Juergen - your resistance values are close enough to spec that I don't immediately suspect an electrical problem.
Is this the 4T65 or the 6T? Different list of suspects. ;) You've probably already checked, but is the fluid level correct?
  • Chad1974
4 years 1 month ago #58236 by Chad1974
It is the 4t45-e transmission. It was a low on fluid, so i did a fluid change and filter. I was able to get a scan tool with bi directional control on it today. No Codes and solenoids responding accordingly.
  • Chad1974
4 years 1 month ago #58424 by Chad1974
Figured this one out. Tubes in the pan that control the low band servo broke at the weld.
