Limp Mode
  • drskrohn
  • drskrohn's Avatar Topic Author
3 years 11 months ago #58894 by drskrohn
Limp Mode was created by drskrohn
Hi. My name is Stu, and I live in New Jersey. I'm having trouble with my 2002 Lexus ES 300. It has 325,000 miles on it, and recently went into limp mode. With the gas pedal to the floor I can only get up to 1800 RPM. I have a DTC code 1127, ECTS Actuator Power Source Circuit Malfunction I've checked everything I know of, changed the throttle body and MAF. The fuse in the engine box marked ECTS is good- power on both sides of the fuse with the engine off, no key in the ignition. I've tried clearing all codes, removing the battery and relearning the idle, but nothing gets it out of limp mode. Any thoughts would be greatly appreciated.
2 years 6 months ago #65442 by Chisoul
Replied by Chisoul on topic Limp Mode
Hey Stu, What was the solution to your es300 p1127 limp mode issue?
  • drskrohn
2 years 6 months ago #65455 by drskrohn
Replied by drskrohn on topic Limp Mode
Hi. It turned to be a short between the fuse in the engine fuse box and the ECM. I had to bring it to the shop and they rewired it. That solved the problem.
Good luck.
The following user(s) said Thank You: Noah, Chisoul
2 years 6 months ago #65521 by Chisoul
Thanks for the quick reply Stu.
