Rough idle, only when in gear.
  • K9MrJim
  • K9MrJim's Avatar Topic Author
3 years 11 months ago #58913 by K9MrJim
Rough idle, only when in gear. was created by K9MrJim
1993 Chevrolet K1500 350tbi. Truck shakes when stopped at traffic lights. Shift into park or neutral truck runs smooth. No DTC's. No other noticeable problems running. I don't have any scanners or scopes. Any suggestions welcome.
Thanks for your time l
3 years 11 months ago #58917 by juergen.scholl
Replied by juergen.scholl on topic Rough idle, only when in gear.
Motor mounts, pinched wires....
3 years 11 months ago #58961 by Paul P.
Replied by Paul P. on topic Rough idle, only when in gear.
There is a little silver welch plug on your TBI unit adjacent the throttle linkage and TV cable.
It's the stop screw that adjusts the minimum airflow to the TBI unit.
You could try and attach a feeler guage to act as a shim too, to see if the problem corrects itself before you drill.
Drill it out, there's a T10 torx screw behind the plug, give it 1/2 to a 1/2 turn clockwise.
Problem solved?
Never stop Learning.
