graphing milli amps
- aaronbuick139
3 years 11 months ago #59046
by aaronbuick139
graphing milli amps was created by aaronbuick139
I have a Fluke 297 that can graph milli amps (in line/not using a current probe) but the sample rate is too slow 1 second per sample.
I wanted to graph amps in the milli amp range 1-10 milli amps
Does anyone know of a tool that has the abilty to graph milli amps--it would need to be in line as I don't think any current probe could detect 5 milli amps
3 years 11 months ago #59047
Replied by Noah on topic graphing milli amps
Snap-On Vantage mt2400 is my tool of choice. Can graph very low mA through the internal amp meter.
The Vantage pro also has an internal amp meter, and is a graphing meter, but I don't remember if the two functions overlap. I can check tomorrow
- Matt T
- Thank you received: 276
3 years 11 months ago #59049
by Matt T
Replied by Matt T on topic graphing milli amps
I scope voltage drop across the mA shunt in one of my DMMs. You could use an resistor instead if you don't have a DMM with a mA shunt. Have to be careful if your scope has a common ground but other than that it works great.
Another option is using a current multiplier loop with an amp clamp. This option won't nuke your scope or DMM :silly:
A microamp current probe will go that low but they ain't cheap. Attached pdf has some screenshots taken with one.
3 years 11 months ago #59050
So you set the meter up in series like any amperage measurement, and scope voltage across the meter leads?
Speaking of low amp clamps, I just saw this on AES Wave,
www.aeswave.com/High-Accuracy-Low-Curren...mp-Meter-p10169.html
It's a stand alone so no output for a scope, but if the 1mA resolution is to be believed, $200 seems like a decent price.
- Matt T
3 years 11 months ago #59052
by Matt T
Yeah you just scope voltage drop across the meter. Meter doesn't even have to be turned on. IIRC Andy has a tutorial somewhere on here about using a DMM as a shunt.
3 years 11 months ago #59053
