97 GMC Sierra 5.7L. Crank, no start.
- 70monte
- Thank you received: 29
This truck had gotten a new Delphi fuel pump about two years and about 11,000 miles ago. I test for fuel pressure and it's 0. Won't even move the needle even though there is fuel at the shrader valve.
I switch the fuel pump relay out with the one in my 98 Chevy Silverado with the same engine and that does not make a difference. I can't hear the pump prime because of the buzzer when you turn the key on so I wait until my fiancé gets home so she can turn the key on while I get under the truck. I can hear the pump run but it's not very loud.
Tomorrow I'm going to jump pins 30 and 87 in the fuse box where the relay goes and take an amperage reading to see what I get. I saw Paul do this test on a 97 chevy truck to see if the power and grounds at the pump were good so that he didn't have to try and access the connector at the fuel pump which is very hard to get to on this truck.
What else could be causing this symptom? Fuel pressure regulator? How do I test the fuel pressure regulator? Thanks for any other ideas. I don't have a wiring diagram for this truck so I don't know if there is any other electrical stuff in this system. All the fuses in both fuse boxes looked good.
I just want to make sure that I rule out everything else before replacing the pump again.
I did put my scanner on the truck but no current or pending codes in the ECM.
Been a while since I worked on a 97, but I think it still has an inline fuel filter. Probably not a bad idea to change it as that will get clogged and cause low fuel pressure. I never bother testing pressure before the filter and after it to see if it's clogged. It's a maintenance item, an if I have to touch it, it's getting a new one.
Also there's a ground on the frame not far from the tank that is pretty well known for taking down the fuel pump.
You can put a test light on B+, to pin 87 of the pump relay slot in the fuse box. If it lights then the circuit to the the pump, the pump windings and the ground are intact.
Happy hunting!
- 70monte
Truck has 73,000 original miles so I'm not sure how dirty the inside of the tank is but I guess it could be an issue because of the age of the truck.
- 70monte
I also tried the test that I mentioned with the amp clamp and got no amp readings. I used my factory service manual for my 98 Chevy truck and looked at the wiring diagram for the fuel system electrical and hot all the time power is supplied at pin 87 which I verified. I also verified that I had a ground on pin 86. I had power at pins 85 and 30 when I turned the key on for the two second prime and then my test light went out like it should.
So right now I'm still not sure if I have a good ground at the pump. I had someone listen under the truck when I turned the key on and he could hear the pump come on and prime. The battery was getting weak so it's now on a charger.
- ontheriver
- Thank you received: 16
- 70monte
There's some Scanner Danner videos on YouTube that demonstrate the purpose of that circuit.
In any case, if the pump runs but does not build pressure, then you know it's getting power and ground. You did your due diligence and changed the filter and cleaned the ground. It really can't be anything but the pump as I see it right now. Obviously, load check the power and ground when the tank comes out, make sure there's not a bunch of crap in the tank and install a quality part.
- juergen.scholl
- Active partschanger
- Thank you received: 462
If you have to change the pump: instead of dropping the tank or taking off the bed often times it's enough to just loosen the bed on one side and unscrew it on he other. Then you'll be able to lift/tilt the bed enough to get to the pump without pulling the entire bed. This will not allow to cleanp the tank properly though
As Noah already said, the oil pressure switch will not prevent the pump from working: it only acts as a backup to bring power to the pump in case the relay goes south. In that case it will take extended crank to build up oil pressure which makes the contacts close.
I understand the fuel filter is in there for 2 years. If so, change it anyway
- 70monte
When I jumper pins 87 and 30 at the relay and go under the truck, the pump is not on. Why would the pump work during the prime but not when I jumper the two pins together?
This relay has a pin 87a which according to my wiring diagram, goes to the fuel pump prime connector. Is this why I'm hearing the pump prime when turning on the key but nothing when jumping 30 and 87?
- 70monte
- juergen.scholl
Measure resistance between the feed terminal 87 or 87a in the relay socket and ground. If it's infinite you got an open if it's close to 0 there may be a short to ground. Typically it should be 2 ohms , give or take .5 ohms.
If in specs you may want to use a fused jumper wire and feed the pump directly with voltage into the relay socket, could be pin 87 or 87a, doesn't matter.
- 70monte
Thanks for all of the help.
- rockp2
- Thank you received: 40
EDIT: I also had to get around the stem in the gauge also. Don't remember if I disconnected that portion from gauge, used an adapter, or pulled that stem also. Just know I had to have no obstruction between the Schrader valve and the gauge head to get a reading.
- 70monte
- 70monte
- juergen.scholl
I wish I could loosen truck beds to change fuel pumps!
New England road salt has taken that option off the table unfortunately, lol
- 70monte
They do salt the roads here in MO but this truck only has 73,000 original miles and isn't used on the roads that often in the winter when the roads are salted. It's mostly used as a farm truck. The bolts came out fairly easy luckily.
Thanks again for all of the help.
