Light illuminated on dashboard causing a steering and other problems
- davidessiendcarguy
3 years 10 months ago #59407
by davidessiendcarguy
Light illuminated on dashboard causing a steering and other problems was created by davidessiendcarguy
A client complained that when he was on motion is airbag shot. Eventually, he noticed that the smoke was emanating from the engine bay. Hence, he pop-up the hood and saw that the smoke was coming from the ABS module. He called a mechanic to unplug the ABS module connector. Afterward, the connector was connected back. Henceforth, he has noticed that his steering is stiffer to steer. Additionally, he said : "the car isn't moving smoothly as before."
Yesterday, he called and said even the headlight and other lights aren't working again in the car.
The check light appears first, brake light second then finally the P/S light appears. They lights don't come out at once. It's a 2010 Toyota Corolla Le.
Please how do I fix the problem?
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 10 months ago #59408
by juergen.scholl
Replied by juergen.scholl on topic Light illuminated on dashboard causing a steering and other problems
You may want to start with a full system scan confirming communication and possible DTC.
- Baraka
3 years 10 months ago #59419
by Baraka
Replied by Baraka on topic Light illuminated on dashboard causing a steering and other problems
On this brand of toyota corolla the abs module plays a vital rule on road performance, I think the general system scan will be the best option on this issue
3 years 10 months ago #59507
Replied by davidessiendcarguy on topic Light illuminated on dashboard causing a steering and other problems
The client is a novice about car and was unable to give me a good explanation. I didn't see any sign of airbag shooting when I saw the car personally. I told him that the airbag is still Ok. He made a mistake in his explanation. The only thing I saw was that the ABS connector was unplugged and headlights were bad in the car.
What i noticed from the car was that when it's first started the RPM raise to about 2,500 and then drops to about 700 RPM on it's own.
Probably there could be a short on the instrument cluster as well because I noticed a blink once after about every 25 seconds throughout idling except the car is shut-off. He said that was how it was when he purchased the car from someone till date.
In addition, the speed clock doesn't raise when driving and the car is intermittently hard to start.
P0335 and P0500 were the only codes I retrieved
- shotgun
3 years 10 months ago - 3 years 10 months ago #59553
by shotgun
Replied by shotgun on topic Light illuminated on dashboard causing a steering and other problems
i would start by following the p0335 and sorting the Crank position sensor/circuit issue first. get the starting and running sorted so i had a stable platform to chase the other issues.
Last edit: 3 years 10 months ago by shotgun.
