Negative Long Term Fuel trims while cruise speed
  • Juanchos
  • Juanchos's Avatar Topic Author
9 years 6 months ago #9273 by Juanchos
Hi Guys,
I've been looking for opinions on fuel trims.
Montero 2006 3.8l V6.
New Sparks, wires, coils, air filter, and both O2.
While at cruise speed around 2000 rpm 60 mph long term fuel trim for both banks average negative 3.9, short term in both banks oscillates from minus 7 to 10 and positive 7 to 10 (in that ballpark)
Long terms never go positive at idle or cruising , idle is king of rough at parking (no load) fuel efficiency has decreased.
9 years 6 months ago #9274 by Chad
+/- 10% is normal. A long term fuel trim of -3.9 is nothing to be concerned with, in my opinion.
9 years 6 months ago - 9 years 6 months ago #9276 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Negative Long Term Fuel trims while cruise speed
Cruising fuel trims are well within bounds but for diagnostics they are more valuable when compared with the fuel trims at idle. If there is a big difference between the total trim at idle and when cruising then it can be pointer to a vacuum leak or MAF or fuel pump fault.
For example With a vacuum leak especially on a MAF engine the fuel trims add fuel at idle but go negative at higher RPM but that isn't the case for your vehicle.
Where you get a low speed roughness or misfire that goes away at higher RPM particularly coupled wth higher fuel consumption then a compression test is worth considering.
Last edit: 9 years 6 months ago by Andy.MacFadyen.
  • Juanchos
9 years 5 months ago #9282 by Juanchos
I thought of that and certainly I've not done a compression check since is kind a pain in this engine due to the plenum has to come out to do it, however there is no smoke at tail pipe and no blow-by is felt thru the PCV orifice on valve covers (pcv removed).
I know the tests I've described are no definitive but car is only 66k miles and very well maintained (bought it used).
Still kind of puzzled since those long term trims do not go positive...
LOL...
  • Juanchos
9 years 4 months ago #10176 by Juanchos
Now the vehicle has developed a slight hesitation, gas pedal lag!
8 years 2 weeks ago #24133 by winchester9647
Replied by winchester9647 on topic Negative Long Term Fuel trims while cruise speed
Did you ever figure out what was wrong. This sounds just like my 2013 F150 5.0
8 years 1 week ago #24164 by Tutti57
What are the total trims at idle vs 2000 rpm in park? Total trims are combined short and long term.
8 years 1 week ago - 8 years 1 week ago #24171 by winchester9647
Replied by winchester9647 on topic Re:Negative Long Term Fuel trims while cruise speed
Mine are hard to calculate off idle they jump so much both long and short. 0 at idle and at 2000 in park they go to -20 then when you let off the gas they go to say 15 and eventually come back to 0. I think I figured mine out last night. I had an 02 fail and had a cat melt down on me a few months ago. Both cats replaced along with all 4 02 sensors just for good measure, she's got 125,000 miles on her. I got to thinking about whats happening with trims and figured it had to be an exhaust leak but can't find one, last night I put snoop leak detector on the manifold collectors and sure enough when my nephew hit the throttle it bubbled pretty good. I'll update after I change the gaskets this weekend and let you guys know whether this was it. BTW it was the Ford dealer who replaced the cats ;)
Last edit: 8 years 1 week ago by winchester9647.
