04 chevy silverado 2500hd 4x4 6.0
3 years 9 months ago #59824 by Solo
04 chevy silverado 2500hd 4x4 6.0 was created by Solo
obd po300 on scanner misfire data shows on cold start up all over but after warm up when at idle cyl 2 & 7 when in motion cyl6 is the one misfiring but theres not one cyl thst doesnt misfire plz help
3 years 9 months ago #59828 by Hardtopdr2
Replied by Hardtopdr2 on topic 04 chevy silverado 2500hd 4x4 6.0
what are the misfire counts for each cylinder?
how often does each cylinder misfire? 1-3 times per misfire cycle before misfire counts reset on scanner?
let me know
3 years 9 months ago #59829 by Solo
Replied by Solo on topic 04 chevy silverado 2500hd 4x4 6.0
Cyl
1-0
2-20
3-4
4-14
5-4
6-20
7-29
8-0
But jumps around a lot when first stated it up nothing was misfire n
3 years 9 months ago #59867 by Hardtopdr2
Ok with it being that low of counts well need to check several things
1 fuel trims... if you have graphing capabilities well need to look at o2 sensor voltage readings for bank 1 & 2 upstream and down stream.
2 maf and map sensor readings at idle, 1500, 2500 rpm
3 condition of spark plugs (when was the last time they were replaced ? What do they look like (black soot covered to Tanish white ) pics would be ideal...
4 fuel pressure at idle and key on engine off and does it bleed down fast or stays at that pressure for a while?
5 condition of throttle body is it dirty around throttle plate (if yes clean it with throttle body cleaner)
6 condition of fuel did this happen after a fill up? Bad gas is possible rare but possible
7 air filter is it clean or needs replaced?
Has a rats nest in filter housing etc
Time to create page: 0.256 seconds
