2016 ram 3500 win module
  • Cheryl
  • Cheryl's Avatar Topic Author
3 years 9 months ago #59893 by Cheryl
2016 ram 3500 win module was created by Cheryl
Someone busted the win module. Does anyone have programming instructions for the win module and keys. Only thing I can fin is if radio frequency hub is replaced. Looked on mitchell. Just trying to see if anyone has installed a new win module in a newer ram with a fobik not a push button start
3 years 9 months ago #59895 by Tyler
Replied by Tyler on topic 2016 ram 3500 win module
I think in your case of non-push button start, the part you're replacing is called the Ignition Node Module (IGNM). Not trying to argue semantics. :silly: But the service info makes a distinction.
The installation info for the IGNM is pretty straightforward:
I haven't done one of these in a newer RAM, but I have done a couple in Journeys and Caravans. Ended up borrowing an Autel IM608 to get the job done.
  • Cheryl
3 years 9 months ago #59896 by Cheryl
Replied by Cheryl on topic 2016 ram 3500 win module
I typed ignition node module and no search results came up on Mitchell. They Even call it that on the wiring diagram. Just said win because people are used to hearing the word. What is in the link for rfh verification test and fob programming?
3 years 9 months ago #59897 by Tyler
I had some luck searching for IGNM in ProDemand. That takes you here:
The RFHUB Verification Test amounts to FOBIK programming if the RFHUB was not replaced. See how many FOBIKs are currently programmed, provide the security PIN, like that.
  • Cheryl
3 years 9 months ago #59898 by Cheryl
Think that’s where I messed up your actually in the service manual. I used the 1st search option and kept getting no results. Thanks for finding it
3 years 9 months ago #59907 by Tyler
No problem!
  • Cheryl
3 years 9 months ago #59909 by Cheryl
Got one for you same truck no airflow from vents. Can’t really feel air out of defrost or floor. Checked blower motor for clogged squirrel cage and even swapped polarity on the blower no change. Took mode actuators off and moved doors by hand no change. Pulled dash but don’t see any broke doors. Have you seen evaporators get plugged up with dirt that allows hardly any airflow movement. It doesn’t have a cabin air filter. I’ll probably crack the case open look. It’s a landscaping truck
3 years 9 months ago #59912 by Tyler
I've seen plugged evaporators, but not on this YMM specifically. Is there anywhere you could stick a borescope into the HVAC case and get a look?
  • Cheryl
3 years 9 months ago #59913 by Cheryl
I was just asking in general about the evaporator. I don’t have a bore scope yet.case is sitting on the work bench. The recirculate actuator door just flaps around. So I know it’s broke. I’ll let you know what we find
3 years 9 months ago #59914 by Tyler
:lol: If you do open it up, I'd love to see pictures.
It's a bit late now, but all the previous plugged evaporators I've seen all showed low Low side and low High side pressures, despite being fully charged. Without enough airflow, the evaporator would get too cold and never exchange any heat.
But it's also January right now, and most A/C systems are fast cycling anyway. :silly:
  • Cheryl
3 years 9 months ago - 3 years 9 months ago #59915 by Cheryl
Evaporator plugged up mouse nest all a crossed it shouldn’t of cleaned it out but that’s what it looked like had pine trees in it and looked like house insulation
Last edit: 3 years 9 months ago by Cheryl.
