2007 Chevy Silverado Classic 1500 4.3L: Will not go into closed loop
- SK
- Thank you received: 8
3 years 9 months ago #59899
by SK
2007 Chevy Silverado Classic 1500 4.3L: Will not go into closed loop was created by SK
Subject vehicle came in with a cylinder 5 misfire. Truck has over 200k miles; owner had already changed plugs, wires, and ignition coil, but still had the misfire.
I scanned the computer and there were a lot of DTCs, so I cleared all codes to see what would return.
I got a P0200 (injector circuit open) and a P0300 (random misfire); when I looked at misfire counters; only cylinder 5 was incrementing. I found the cylinder 5 injector was open, so that will get changed once I verify the PCM driver circuit is working.
All of the O2 sensors were replaced with OEM sensors, but the engine will not go into closed loop with a warm engine; engine temp reads normal on the gauge and on the scan tool.
What other parameters are needed (besides a hot O2 sensors) for the PCM to go into closed loop?
3 years 9 months ago #59902
Replied by Noah on topic 2007 Chevy Silverado Classic 1500 4.3L: Will not go into closed loop
Misfires and trouble codes can stop the PCM from enabling closed loop.
I suggest fixing what you have proven to be broken and moving on from there.
The following user(s) said Thank You: Love learning
3 years 9 months ago #59906
Replied by Tyler on topic 2007 Chevy Silverado Classic 1500 4.3L: Will not go into closed loop
Agree with Noah. It's not unusual for the PCM to force Open Loop in response to a misfire or injector fault.
- SK
3 years 9 months ago #59993
by SK
Replied by SK on topic 2007 Chevy Silverado Classic 1500 4.3L: Will not go into closed loop
You guys were spot on!!! I changed out the faulty injector (buried under the intake manifold ... I mean come on GM; who makes these decisions on injector locations???)
Anyway, I cleared the DTC for the #5 injector, and right away my fuel trims were showing activity.
Thanks!
Thanks!
The following user(s) said Thank You: Noah, Love learning
3 years 9 months ago #59998
Well done, glad you got it sorted out.
