2012 Dodge Journey RT battery sensor testing
  • robert.lesaca
  • robert.lesaca's Avatar Topic Author
3 years 8 months ago #60297 by robert.lesaca
2012 Dodge Journey RT battery sensor testing was created by robert.lesaca
Knowing this vehicle whose battery is located, of all places, by the driver side wheel well, what is the easiest way to test the battery sensor?
Thank you.
3 years 8 months ago #60302 by Tyler
Without accessing the sensor directly? There's not many good options. :unsure: The battery current sensor has an independent LIN network that it uses to talk to the BCM, so you'd have to access the BCM to get a signal. Getting to the BCM may be worse than the battery...
You'd also need to check the sensor power feed before calling a bad sensor. It's fed by fuse 179 in the Power Distribution Center. There are no other splices or connectors in between.
What led you to suspect a battery current sensor issue?
Time to create page: 0.263 seconds
